ENERGY AMPLIFICATION... REVEALED!
Started by Dave Wing, January 06, 2015, 12:55:27 PM
Dave Wing
Hi all,
I have proven this concept on the bench and it in fact does work, if you want energy amplification that is.
Thomas Bearden has stated or hinted at the fact the modern electrical community has failed to realize or suppressed the knowledge that energy can be used more than once in a system, as it can neither be created or destroyed, we are free to use multiple pass techniques if we can find such a way to do it efficiently.
-Dave Wing
that_prophet
YESSSS,,,,,,
I fully agree with amplifacation
as in, ELECTRICITY MULTIPICATION
Come on guys and gals
Let's get with the program
THIS WORKS and is so logical that it must work
You put a very small amount of DC electricity into a motor
That has a large 100 cm circumference pulley + only has to rotate once
Then you use a belt or strap to connect it to one or more mini pulleys,
That are of 1 cm circumference, which rotate 100 times + have AC motors
So you put in 1 unit of DC electricity
To gain 100 units of AC electricity = 50 – 100 electricity multiplier
Please remember, you could add many mini pulleys as you want
Multiplying your electricity by massive amounts
Don't listen to Satan's torque arguments
Think of how easily mini motors turn
It takes practically no effort
This is not only free energy from God =(Eze 1:16)
DIAGRAM + DISCRIPTION @ http://free-energy.yolasite.com/
Not only do we know free energy as Truth, but it is also good news twice
1) This will take away massive sums of money given to nations growing terrorists
+ This is info from The Big Guy Himself, so
2) This was found as a description of the workings of a UFO, so we should be able to discover antigravity, or be able to figure what ever helps these UFO'S levitate + travel so fast
(EZE 1:16) The appearance of the wheels and their work was like unto the colour of a beryl: and they four had one likeness: and their appearance and their work was as it were a wheel in the middle of a wheel.
as in, a little wheel inside a big wheel, but I could not afford to buy a big wheel with threading on the inside, and a mini wheel with the same threading on its outside. So I did the next best thing, I connected a big wheel to a mini wheel through a belt, strap, rope or even a piece of string in a pinch to connect the two pulleys with motors attached. This was easier to build out of many parts that one might have around, especially for the Tribulation Saints, when they are running from the evil authorities = in less than 5 years. http://my2020vision.yolasite.com/
Please remember this, when before 2020 the Tribulation starts =
the 7 year peace treaty signing with Israel = START OF TRIBULATION
Please view all the info that I have picked up @ http://beliefstoliveby.yolasite.com/
He gave me these two other Gifts also @
http://ultimatejoysticks.yolasite.com/
(an awesome next generation joystick = measures movement in all three axis's + measures rotations in all three axis's = that's 6 movements = 3 times basic joystick) -
AND http://ultimatevideogamecontrols.yolasite.com/
(which is awesome 3D virtual reality room = video on all 4 walls + ceiling + floor + you are held in the centre by cables to each corner. you are standing non a mat of bearings so you can walk or run in place, while graphics move around you )
These are all free for all to use, as they are displayed on the web + are without patents
We should use these to earn plenty of income to help spread the Gospel.
http://fire-starter.yolasite.com/
Before http://my2020vision.yolasite.com/ occurs,
Door closes on Christ return http://doorschristmustpassthrough.yolasite.com/
Now first off let's loose this fairytale of EVil-sOLUTION
God proves it wrong with His Creation Hourglass = MOON=
it only has 6000 years (very small amount) worth of sand on it,,,,,,
http://decimationofthisevolutionfairytale.yolasite.com/
FREE ENERGY
The only reason that this has not been used earlier to create free energy, are the billions of fallen angels, trying desperately make sure that we never discover this technology
gyulasun
Quote from: Dave Wing on January 06, 2015, 12:55:27 PM
Hi all,
-Dave Wing
Hi Dave,
Thanks for showing this setup.  My question would be whether you considered running the system with precharged capacitors instead of batteries?  If not, what do you think?
Gyula
Dave Wing
Hi All,
What one needs to do is put switches on each negative side and run one loop at a time starting with a load across the single 12 volt battery and progressing onward. Run the 12 volt battery with the motor across it for 10 minutes. Then run the next closest section 24-12volt for 10 minutes it will charge the 12volt battery and put back in what you took out. Then move up the line to the 36-24 volt section and do the same thing. Rpm's of each motor will drop as you move up the line, because the differential will become closer  however the battery will still charge in the 10 minute runtime period. That is what I have found... So far. Of course the last battery set will not charge... But if you took a percentage of the shaft energy and stored it to put back into the 60 volt section you may have a free runner. I have not yet done this though...
In order to increase rpm's of the motors in the later stage like the 48-36 and 60-48 volt sections, differential may need to be increased to 60-36, 72-48 and 84-60. Because my 12 volt batteries easily each charge to over 16.3 volts. So with the 60 volt section running at 13volts x 5 batteries = 65 volts and 4 batteries x 15.8 volts = 63.2 for a differential of 1.8 volts for the 60 and 48 volt section to run on. That is why we need to increase the differential between sections as the voltage goes higher. Just thinking outloud here.
Are we not taking out only 12 volts for 10 minutes out of the 60 volt section at the end but have been able to run the system for 50 minutes for no cost all we have to pay for is the last 10 minutes of the 12 volt differential we have taken. So should it be easy to close loop the system.
In my opinion, again, after spending much time on the bench from what others elsewhere have mentioned the circuit as drawn will and does only function as a series circuit so nothing special there. It had me fooled for a while. But as explained in the above, in the two paragraphs, I was inspired by a fellow member Nityesh from Energy Science Forum, that the switching between each section may be the key. So I modified the circuit and performed the above tests.
-Dave Wing
Dave Wing
Quote from: gyulasun on January 12, 2015, 06:48:07 PM
Hi Dave,
Gyula
Hi Gyula,
It will work if you switch the motor off before the small side cap equalizes with the large high potential cap on the other side, you have to maintain a fair amount of differential 11-13 volts, otherwise the motor will slow down and or stop when equalized. All this is dependant upon actual cap size and switch on time. But it can be done.  Here is the configuration below in the pic drawn up from Matt over on Energetic Forum. If you want to run with caps I want to make a suggestion remove the end 12 volt battery and put a capacitor there with the motor across it. Keep all capacitors empty and run the circuit in steps from the 60 volt side down to the last capacitor and finally the motor.
One could use one motor just switch it in and out of each decreasing potential loop all the way down to the end capacitor. Making sure to switch the motor over to the next capacitor section prior to anything smaller than a 11-13 volt differential on the loop in use.
Hope this makes sense, it does in my mind but may not to anyone else.
In all honesty this was just to prove a concept of energy amplification, in the form of getting a motor to make multiple passes with the same energy it uses. After thinking about it... The Bedini Tesla switch does a much better job at making the energy complete multiple passes of the same energy, it simply ping pongs the energy from the right battery bank to the lower potential on the left battery bank and back again. This process repeates it's self over and over again without stopping it produces a dc pulsed square waveform and re-uses the same energy in multiple pass format to  run a AC load for free or for a very long time. The Bedini Tesla switch is the only way to go... That is where I am going with all this. If you want something that would work a lot better than what I am suggesting here...  seriously look at John's DvD's and build big and then you will have something.
-Dave Wing
