The 'free energy' spark
Started by pomodoro, January 06, 2015, 02:30:01 PM
forest
Maybe that's why the previous not patented device was composed of two towers ?  ::)
Zeitmaschine
So, as it looks, all electric free energy devices are working upon the principle of the concentric (magic) capacitor. But what if we have only half of a concentric capacitor? Would this also create any unexpected effect?
Example: Working OU device Video from Wesley
Quote:
               »again the strength of the field was tremendous«
Quote:
               »if you once get this magnetic field - you will be amazed«
Yes, apparently they were amazed. :D
Quote:
               »-pain in the part of the head. Felt similar to mechanical impact.«
               »-Pain felt as skin affected when you move your head rapidly.«
Bottom line: Don't use Russian ferrite core for the construction of concentric capacitors. Your head could be damaged.
In January 2012 the yoke page was there, in March 2012 the yoke page was already gone. Today there is still a page named the Lithuania Experiment but there is no trace that the yoke device ever existed. Wonder why. Because they hit by chance the principle of the »magic« capacitor, but although an odd effect was clearly present, it was mysterious at that time what really caused that effect?
Now we see more clearly.
In order to generate the effect the yoke device needs two synchronized generators G1 and G2. Accordingly the Stepanov device seems to work also with two frequencies. 50Hz base frequency (like yoke device) and synchronized 100Hz generated by a frequency doubler circuit.
Forum-technical hint:
If now someone gets very enthusiastic about those findings, so therefore he absolutely needs to post oversized drawings, the solution to that is a Firefox plugin called Stylish. Copy the following lines into that plugin and that oversize image problem will be eliminated:
@-moz-document domain("overunity.com") {
  .attachments,
  .post {
    width:805px!important;
    overflow:auto;
Magluvin
Here I have a better resolution of the tower base circuit. I numbered the LC coil windings and it looks isolated to me. I skipped through the pat and I dont see that it describes a spark gap at the top of the described ground plate at the bottom of the pic so far. It looks like there may be something other than just a wire connection there. Maybe the pat description is not telling the whole story on the device.
Im kinda wondering if what I described as a self powered tower may work. According to many other Tesla patents, a spark can be had with a tower of this sort. And if the gap were tuned, probably needing tuning quite often due to weather and other conditions, to spark at a high enough repetition rate, the LC could be kept going.
Im reading it over as it talks of resonance with the main coils and the LC.
It describes G (here below the cap is to the left) as either a cap or a generator.  ???   So why show just a cap there instead of a generator? Seems very odd to just depict a cap as sole input, without any further idea of how the cap gets its charge. ;) Doesnt jive with other Tesla drawings where he would at least show some sort of input lines with at least a simple gen symbol or something. ??? ;)   Maybe he was showing something without actually telling. :o ;D
The tower looks like a self standing unit with no wired input of any sort. ??? ;)
Mags
jbignes5
 My point exactly Mags...
If you look at the diagram I put up earlier of the Tower, well that was from the notes going from Colorado to the Island.
It is very clear Tesla had other intentions for this device. The spark gap at the end of coil A which is an extra coil setup connecting to the very high capacitance top load. He used special single terminal tubes to disperse the High voltage back rush over the surface area of those single terminal capacitors. Kinda like a Leyden jar. This did two things. It gave the Tower something to collect the recoil from the spark gap at the ground connection. This charged the Top load immensely and attracted the plasma from the upper atmosphere down to the Tower. This allowed the top load to be charged to very high voltages because it was shorted to the ionosphere, which value is at +360k volts as we all know. Now it isn't a true shorted connection so it's value would be less but think about it. 200k volts or there about, going into the ground via the spark gap.
We know Tesla used the spark gap in his radiant energy patents (figure 1&2). This is no difference if you know Tesla's methods or if you are schooled in the arts as Tesla would say.
"(figure one) "Again in Fig. 19 two transmitting circuits, one grounded directly and the other thru an air gap are shown. It is a common observation that the former is far more effective, which could not be the case with Hertz radiations. In a like manner if two grounded circuits are observed from day to day the effect is found to increase greatly with the dampness of the ground, and for the same reason also the transmission thru sea-water is more efficient.""
The spark gap could be modified with a magnetic shunt and a special trigger point to get the process started (figure 3). I assumed the spark gap was housed below ground to shield most things from the radiant energy blasts that Tesla's disruptive circuit causes.
At point G would be the normal Tesla discharge circuit as I drew out earlier. This allows one to convert the impulses into AC via a solenoid excitation via the impulses after point G discharges to ground (virtual as well).
Why exactly do you think they tore the Tower down? It wasn't because of them thinking the Germans would get it, oh no... It was because he hid this very fact from his financier Morgan that the tower was demolished.
If you read the text, well don't. It was only to get this past the Patent process. Refer to his Radiant harvesting techniques to piece this one together.
I think output of this device went to ground and radiated away from the ground. One huge capacitance just like the top loads on the Lodge coils (Tesla coils) of this day. He was broadcasting from the ground into the air as well and could harvest energy or intelligence at will and even using a virtual grounding system with it. The Tower was essentially free just like Niagara falls as and he hooked his system to the very wheel work of nature. The only cost would be building the device, everything else was free just like in Niagara Falls.
Listen this tower is nothing but a controlled blocking oscillator. It's that simple.. Powered by the voltage difference between the ground and the atmosphere.
Once it was fluttering away all he did was disruptively discharge the Cap G into a bifilar coil/Solenoid coil transformer and out an antenna or virtual ground.
Magluvin
Quote from: sparks on November 13, 2016, 12:17:34 PM
https://en.wikipedia.org/wiki/Electron_capture
   The electron avalanches produced in extremely high voltage fields may well be the result of K-capture.  This is when a K orbital electron is captured by the nucleus.   If the nucleus has an abundance of protons the capture will convert a proton to a neutron,emit a neutrino and leave an isotope of the next element to the left in the periodic table.  The electrons in the outer orbitals will fill the hole in the k orbital and emit a photon in the xray spectrum.  Tesla was experimenting in what one could call high voltage fields.  Producing many an avalanche.  A fairly new discovery is that run of the mill lighning storms produce gamma and xray photons.  This is a sure indication that something nuclear is going on in the clouds.  I wonder if Tesla at some point in his research became aware of nuclear reactions induced in the gases surounding his coils.  I would think that the probability of K-capture would be greatly enhance by the initial ionization and susequent acceleration of electrons donated by gasses finding themselves near the top load capacitors on his transformers.
http://www.bbc.com/news/science-environment-12158718
Hey Sparks
Been a while. Wondered where you were.  Good to hear from ya. Looked back at your posts, its been a year.
Mags
