Showcase of The Unity Generator : +200% OverUnity and climbing!
Started by Majestic81, January 08, 2015, 05:59:40 AM
Majestic81
I hereby would like to present the Unity Generator and the Free Energy Party.
https://www.facebook.com/groups/freeenergyparty/
http://www.freeenergyparty.org/
The Unity Generator is an energy multiplier / QMoGen with a PMDC motor driving a 10KW PMAC generator.
Developed by the Unity Corporation and crowdfunded with the help of the Free Energy Party.
I am not the inventor nor the initiator of the FEP [Free Energy Party].
I am one of the admins of the party and a fellow free energy enthusiast.
Now back to the generator!
11-29-2014
https://www.youtube.com/watch?v=9t4H3MoX8Ww
We showcased the generator [after a small introduction of the FEP] running for the first time without a LOAD, demonstrating overunity.
1-5-2015
https://www.youtube.com/watch?v=6W8ymwwdU0s
We showcased the generator running on load showing the following measurements.
Transcript of video
IN : from mains to AC > DC PSU
2.6A @ 110V
2.3A @ 110V
Total 4.9 Amps @ 110V = 539W
Used power PMDC Motor
1.3A @ 39.6V = 51.48 watts
OUT from Generator to Capacitors
7,4A @ 123.5v AC = 913.9W
7,5A @ 123.4v AC = 925.5W
Total = 1839.40W AC
3500% overunity on raw design!
51.48W DC IN to PMDC Motor > 1839.40W PMAC Generator
= 35 x more energy out than in!
Load on the capacitors
1.Tile-saw dryload 120v @ 4.6A = 550W
2.200w lamp
3.100w lamp
4.100W lamp
5.Saw using 115v @ 4A dryload = 460W
Total load from capacitors = 1310W
1-6-2015
https://www.youtube.com/watch?v=CrUEjcWGpxw
We did another running test outside in the light.
We know the importance of running tests by an independent test lab and are at the moment in agreements with one.
I am not fully known about the inner workings of the device but all used components are shared in detail on the Unity Corporation facebook site as this is a crowdfunded funded project.
https://www.facebook.com/UNITYsystems?fref=ts
Theory behind The Unity Generator.
Karl Palsness' Theory
From a interview with Karl Palsness, who is an expert on Tesla technology.
He has also heard of several cases like this, all independent from one another.
"I know exactly what you're talking about. I've done a lot of work in that area. That's amazing. I've heard this from so many people now, that this works.
"From what has been observed, you're playing with the phasing angles between the motor and the generator, and when the phasing angles are out of phase, you're getting into what is called 'power factor'. When you get the power factor right, the current and voltage are out of phase, and when you get them meshed up enough, it actually self-runs and produces excess energy.
"This theory is based on magnetic flux. Permanent magnets or electromagnets such as in a generator or a motor, under certain conditions, give overunity (OU) behavior. But there's more to it than that, from what I've seen myself in overunity devices. It is all about geometry of the system. How and where a permanent magnet gets it's energy, is still a very big mystery to science. Excess energy can appear in electromagnets, as well.
"I've seen this effect on generators. When you have a generator that's turning too big of a load, and you have big enough breakers to handle the current, the currents go way up. Imagine if you have 500 Volts at 1 Amp; you have 500 Watts. Or you can have 500 Amps with one Volt; and you have 500 Watts. So when you get huge amps and low voltages in between the phasing angles, the current and magnetic fields are so collapsing and rising, and the phase angles are 'wrong', I believe that the magnetic field is coupling with, I'd have to say the word: 'The Vacuum'. In other words, it's coupling with an unknown -- whatever makes the permanent magnet work. We truly don't understand the science of that. There are a lot of theories, but no proof yet. Permanent magnets are still one of those unknowns, as to why it does what it does. And that's the same thing with electromagnets. There are a lot of unknowns.
"So when we kept playing with the power factors and phase angles, I believe there is overunity. I've seen it so many times now, with so many different people, that if I had the money, I would go out and buy the parts to do the testing in this area myself.
"Remember that guy [...confidential / U.S....]. He's doing the same thing. He has a small motor turning a big generator, and it's out of phase, and the power factor is out. There's a guy in South Africa that's doing the same thing. He's got a motor connected to a bigger generator, and it's doing the same thing. There's a guy in South America, (the blind guy from welding) (Force Multiplier System). He had a motor turning a generator, via shaky gear connection. That's doing the same thing.
"There are a lot of people claiming this. It's getting to the point that there are so many people claiming it, that are unrelated to one another, that I'd have to say that it holds a lot of potential.
"And I have a theory behind it. I actually wrote a whole chapter on that in my book about the science of how to do it in a much more elegant method than they are doing it now, based on what they are doing right now. The problem is, I don't have the funds to do it. That book is my research journal, and I don't have plans at the current time on publishing it – my notes as you work every day. I've got a lot of time and money into that. If what they are doing indeed works, I believe it can take it to the next level and make it a much better product and bring it to market. At the current time, I don't want to give that idea out, as it is still just an unproven theory of a way that might work. I'd like to bring it to fruition in the future if I can prove it works."
We would also like to introduce our Indian team, making great progress in India with their OZZOG gravity generator.
Contact details
Home
https://www.facebook.com/perpetualgravitylab?fref=ts
Presentation of OZZOG generator.
https://www.youtube.com/watch?v=Uw5qBslCftg
OzzoG lighting Ganesh Pandal.
https://www.youtube.com/watch?v=ThOYhZVr-wM
Where is your demonstration of it self-looped, running itself without external  power, for long enough to rule out internal stored energy?
I note in the _ cell phone_ video that the device appears always to be connected to a very large battery.  Is that correct? Have you got a video showing it running without the big battery?
Majestic81
TinselKoala,
I do not understand your question as it is clearly told in the video what the connection points are and if you could not understand, there is a transcript of the same.
The device is not self-looping in this iteration.
lumen
Quote from: Majestic81 on January 08, 2015, 09:34:57 AM
If it's not self looped then simply take your eye candy and go back home!
There are many bad meters bad calculations bad measurements bad videos and bad people to try and pedal this bad idea in a bad way.
TinselKoala,
I understand perfectly well. You have presented a poorly shot video showing a jumble of wires all over the place, a big battery and some kind of motor-generator device, and some "measurements" made with a handheld clampon meter.
"This device is not self-looping in this iteration" and will never be self-looping in any other iteration  because it is not actually producing more energy out than it takes in from its power source.
What part of my question do you not understand? The claim is made that it produces 3500 percent OU, that is, 35 times the energy out that it takes in to run it. Where is the proof of this? Certainly  not in the video you have linked. It would be a trivial exercise to self-loop such a device, well within the capability of any of the electrical experimenters on this forum. Yet somehow it is not within the capability of this claimant. There is one obvious conclusion that can be drawn from these _facts_.
You seem not to understand how easy it is to produce false readings, intentionally or by mistake, using the kind of instruments and procedures that are shown in the video. If you could not understand, there are plenty of places where you could educate yourself. And if you truly want independent and proper testing of the device, this can be easily arranged; the only difficulty will be the extent of the cooperation extended by the claimant.  I can arrange for such testing to occur within the week, and I myself will have no part in it other than making the connection between the claimant and the laboratory or testing group.
