0 Members and 100 Guests are viewing this topic.
verpies
Quote from: tinman on May 07, 2015, 05:33:28 PM
Do the two colors in the full winding depict field's?-->is blue south field,and red north field?
No.
The legend in the diagram directly states that this is the map of magnetic flux density in the crossection of the core.
Obviously red color indicates higher flux density and the blue color indicates lower flux density (B).
verpies
Quote from: TinselKoala on May 07, 2015, 04:17:55 PM
Further, I'm no "superhero"... I'm just a scientist
...but the poll does not have that option, so you must realize that all voters who considered you a scientist chose the next best option ...which is "superhero" ;)
EMJunkie
Quote from: Red_Sunset on May 07, 2015, 04:48:05 AM
Chris,
Interesting visualizations, I might be missing something, for which I need some clarifications
A catastrophic collision(1) and hoops rotating through each other (2)
1..  Can you expand some on why you think this has a relationship to your theorized "bucking" configuration. (beyond bucking = colliding)
2..  How do you see this visualization to help the hypotheses or demonstrate your partnered coils to produce a beneficial output
Regards, Red
Red - Fair questions but I get the sense of hypocrisy?
Ask yourself - What are the most basic fundamentals that constitute the Magnetic Field?
    Answer: Electric Field, the Velocity of Orbiting Electron's - E.G: Inverse Square Law
This is, in all its entirety, the A Vector Potential.
The old, out dated, Iron Filing experiment, only shows one thing: That Iron Filings can be Magnetised!
E.G: Take three small nails - place one on a Magnet, place the other on the end of the other and repeat for the third... (then imaging all of the Iron Filings).  This is the Iron Filing Experiment on a larger scale. Which shows nothing of value except that Magnetic Materials are Magnetic!!!
The Conventional way of thinking of the magnetic Field is Bogus, How we think of the Magnetic Field, is simple Vortices in Space. Where the Orbiting Electron Spin, at P/4Pir2 is the Fundamental underlying cause of the Magnetic Field Illusion. Where, I1/(I2) = (d2)2/(d1)2 being the Inverse Square Law.
It is, however, still useful to think of a "Magnetic Field"
   Chris
EMJunkie
Quote from: MileHigh on May 07, 2015, 12:05:44 PM
Nobody questions the fact that there is a force between two opposing or attracting magnetic fields.  But the fact remains that the two magnetic fields do not interact with each other.
MileHigh - In the case of a Standard Conventional Transformer - Do the Magnetic Fields Interact with each Other?
       Answer: YES
Ever heard of Induction brother?
I am sorry, but this is your biggest FAIL to date!!!
Quote from: EMJunkie on May 07, 2015, 06:57:45 PM
       Answer: YES
      Answer:  NO
The reason I am saying "no" is because the magnetic field inside a transformer core will undergo exactly the same vector addition as previously discussed.
The magnetic filings test is real and true.  The magnetic filings line up with the magnetic field lines because they find their minimum MPE just as surely as a brick falls to the ground to find its minimum GPE.
You are a clueless uneducated guy pitching nonsense about electricity and magnetism.  You can't punch your way out of a wet paper bag.
