0 Members and 85 Guests are viewing this topic.
wistiti
Chris, what are your thinking about air core???
EMJunkie
Quote from: wistiti on October 23, 2016, 08:43:11 PM
Hey Guys, this is great to see!
You guys need to be commended! Not many actually do the work anymore!
@Wisiti - Let there be no Limit, but, personally I have not been able to get good results with Air Core, but LostFox just might have shown us how!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: wistiti on October 23, 2016, 09:56:03 AM
Hey lostfox, am really happy your are in with us too!!! :)
Really a nice clean build. Is in it strange and really interesting the fact that when fully load (short) at the output the input power is low!!! I think, just for that, this poc is a must. Im curious if the short secondary consume more power than the input...? Thank you for your great work!
Itsu, i also see than the result is not the same when using different load... There must have a kind of balancing to find...
@Wistiti - This is EXACTLY right!!!
This Balance is the Current in the POCoils, because this is the Magnetic Field, its the Magnetic Field that does the work, Current x throuh Turns x is the Magnetic Field, so if the magnetic Field is low, then less work can be done!
   Chris Sykes
       hyiq.org
l0stf0x
Hi Itsu, I know I am not as experienced as you.. but I want to suggest you to make at least a small air transformer and test it.. Trust me on that, you will not be disappointed. ;) And all of you guys I made measurements again at the old ferrite setup and there was not gain.. I just had slightly better results than Itsu just by luck I think.
I played alot with the primaries.. And I saw the transformer to act like a simple transformer by just position them differently only.
So first of all I hope that you didn't start yet making it, because I have some good news for you, that will make your life easier.
I test the third coil I had .. I placed it at the position of the unwounded/wounded primary coil.. So I placed to identical coils for primaries..\\
If you place them the same direction they do nothing.. If you place them opposite direction they act as they were Boc :) And we have the same gain exactly!!! I double check it :)
So with few words don't waste time unwinding and winding the one primary.. just use to identical coils and position them to look opposite directions..
Also EMjunkie is right.. primary need thin wire and lots of turns to make two good electromagnets.
Secondary need thicker wire and calculation of ratio of turns to get the voltage range you need. (I would say also alot of turns.. I did it and the gain increased!)
I also tested the primary 90 degrees positioned inside the secondary... Nothing!
I also placed magnetic fields all around with many combinations, and also I tried to place other primary inside the old trying to divert and/or concentrate magnetic field to the outer side of primaries... Nothing and worst :)
So I suggest to team and everyone is interested to stick to the known air coils design. the only difficulty is the secondaries.
I found 2 identical coils from microwave fans (same as Wistiti's :)).. and I am about to make a small air transformer just to duplicate the success, and also to understand few thinks more.
Please test it.. :) More people more thinking power.
ps. We have to start thinking combining 2 or more transformers in the same circuit to make the gain we need!  :o
wistiti
Hi Lostfox!
Can you post a picture or schematic of you new setup? I would like to reproduce but not sure to all understand...
Thank you!
