tinman
 author=hyiq link=topic=15395.msg499311#msg499311 date=1486242531]
   Chris Sykes
       hyiq.org
QuoteBrad, this is all just foolishness, I know, you know and Chet K knows...
No,this is the scientific method
QuoteIt is very clear that you're attempting to dismiss the obvious, to Bemean and to Denounce the technology I am sharing, and this means that you have an agenda behind your intentions.
I do have an agenda--finding the errors.
QuoteThen "all the output power did not go through-or was measured by  the scope or CH meter's" - I proved you wrong!
Unless you can provide a full and accurate schematic,then no-you have proved nothing.
QuoteThen  "Toroidal Choke on the Current on the Input" will distort readings - I also proved you Wrong!
Once again Chris-where is this proof you speak of ?
I ask again,if the CH meters are that good,why the need for a choke ?.
QuoteNow really, the only one here that needs to get a grip on reality, is you and your foolishness!
So lets put your reality to the test Chris.
Post your best POC setup,that delivers this OU you speak of,and i will get straight onto the replication,and post my results.
QuoteBrad, I used to have the utmost respect for you, but seeing how you deceived the people following your RT work, was a real eye opener for me!
What deception was that Chris?.
From memory, i seem to recall you had a tough time even removing the stator core from the steel housing drum,and yet i showed how it could be done in under 20 second's,with no trouble at all.
Drilling a neat hole through the laminated stator core also seem to present some degree of difficulty for you,but i also showed you how that too could be done without much effort.
QuoteYour RT used the same size Motor as I used! The Bore, inside the Coils is only 15mm across, now here you are telling people that the secret is inside the Bore: 3mm Wall thickness x 2  + 3mm Wall thickness x 2  + 4mm Wall thickness x 2  - NOT Including diameter of the Magnet - Not including the diameter of the extra Coil you mentioned...
Perhaps the right diagram for the right RT would do you some justice Chris.
QuoteThat was a real eye opener for me Brad, I was actually shocked at how easy you carried out this deception.
What i carried out Chris,was a series of test requested by,and under the guidance of MarkE and PW. I made it very clear that full disclosure was not on the table before i carried out the tests set out by MarkE and PW-and that was agreed upon.
So what ever motor you decide to place with which diagram,is up to you.
But perhaps we should stick to the subject at hand(that being GG wonder device),and not try some slick !but look over here! move,to avoid discussing the subject at hand.
Brad
tinman
Quote from: hyiq on February 04, 2017, 05:19:38 PM
Most readers wont know, but Brad works for Chet K, many here do!
Chet K is working for Mark Goldes, and others (The Highest Bidder scenario), and Chet K is actively employing Cyiril Smith (Smudge) (X Chava Energy - Mark Goldes Employee), GotoLuc, TinselKoala (Scope Purchase Incident...), and many others!
Working behind closed doors to profit from others Hard Work and Ideas!!! Exactly as all of Mark Goldes multitude of Companies through out history!!!
See now why there is SO MUCH ACTIVE DENIAL!!!
MileHigh was employed to divert active attention from Important information... After not hearing from him for a year or so!!!
Brad saying "He knows his stuff" when for years Brad has argued to the contrary!!!
For those that do not know, Mark Goldes has a very bad rep: Amazing Perpetual Swindling Machine: ...... Mark Goldes' Fraudulent "AESOP Institute"
Chava actively tell people they are: "Chava is in no way involved with Mark Goldes"
I mean, 25+ years in business and never any product to sell???
Beware everyone, there are a lot of very very questionable people here an elsewhere.
  Chris Sykes
       hyiq.org
This information is what got me moderated on username: EMJunkie
Chris
I think you have forgotten to take your med's today
WTF is that sh*t,and who is this Mark Goldes?.
Are we going to discuss GG's wonder transformer,or are you happy to just sling sh*t around all day?
Are we going to be replicating your OU POC setup,or are we just going to talk about it for another 7738 post's ?
Brad
ramset
actually Chris you seem to have grown the model even more so ,I have never met spoken with or even know  this Mark Golde
you have your own little thing going on in your head ,and for clarity ,I never asked for you to be moderated ,you started posting something which resembled this delusion in a thread I started to share Smudges Musings.
you are truly off in a place all your own with this complete and total fabrication ,Stefan read what you wrote there at Smudges thread [I just asked to have off topic posts removed]
and he decided you were way out of line and needed to be monitored.
I have no doubt whatsoever that if Stefan was made aware of this garbage as well as all the innuendos you have made about "him" recently...
you would be much more than moderated.
you are after all a guest in his house ,I see by this complete and total fabrication which you have made [with absolutely no facts whatsoever]
that you do indeed pose a liability/lawsuit risk to Stefan.
this is not good.
Thanks Grandma
hyiq
Quote from: ramset on February 04, 2017, 06:40:56 PM
this is not good.
Knew you wouldn't be far behind Chet Kremens (Ramset) - Bought and Paid For
Go tell Stefan like a good little Minion!!!
Hmm,  Chet K. Employing all Chava's X Employees!!!
  Chris Sykes
       hyiq.org
ramset
Chris
Naaahh
I have to admit that your inspector Clouseau Shtick is more "out there" than I had thought ,
I'm not given you the "out" you wanna fall on your sword and be a martyr ?
so be it ! [but not by my hand ,the "boss obviously hasn't seen your nonsense]
or you could just do what you said you would do two years ago ?
I'm not the guy who came into the Bar and jumped up on the stage and yelled
"Gather round boyz and girls "Overunity !!!
But then the guys who knew how to measure showed up....
is it easier this way "they threw me out" ??
Naaah
Man up Chris
Thanks Grandma
