Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
skycollection
Yes, i show two ammeters, left is watts in and right is watts out...! the efficience consist in that the rotor don´t have friction, lateral friction, (no bearings) the design consist in a good calibration of the rotor and the shaft, when the rotor [/size]rotates freely, the speed is extremely high...! I have a good torque and when i turn on the resistive load, don´t stop the rotor, only affect 20% aproximatelly of the LENZ LAW, the rotor continue with high speed, this design is my best work in years, just take me 2 days inplement the design, some time ago i did a test about the magnets (the two rings) and it was very easy for me to complete the project in short time. I hope other people can make a replication of this machinne, I'm not lying...!
thanks for watching.
Thaelin
Hi Skyc
   Wanted to ask this for a while but not sure if I should. But anyhow,
would you be willing to state an estimated force holding the mag bearings
in place?  Just makes me curious on how stable the shaft is to wobble. I
did a mag bearing some time ago and it broke apart under the stress but
when assembled, it was not possible to move the shaft at all except in a
circular motion. Too big too....
thay
skycollection
Hi Thay, thanks for asking this.......i have a good and bad experiences in this matter, my first maglev was different, i used three magnets, one in the end of the shaft and two magnets down of the magnet,
is like the MENDOCINO SOLAR MOTOR, and this system is very dangerous for my project because i have no stability with high speed, the rotor it shoots out of control and hurting the people in front, i destroyed a PVC ROTOR some years ago, at 23,000 RPM, and i decided to leave the project to be dangerous...!
I never give up, and i decided the change the system by RINGS MAGNETS, the small ring (cylinder) fits into the bigger ring, and part of the shaft is inside of this ring in both sides, is impossible that the rotor
lose control out, the small cylinder repel and avoid that the shaft make contact with the ring, with this system i can turn the rotor at 40,000 RPM without risk of explosion, as you can see in my videos, i can drive the maglev motor at extremelly high speeds without risk or that the rotor go out of control.
I built the rotor with two neodymium magnets, NORTH-SOUTH, inside of a COPPER PIPE, I chose this metal because it is very safe, strong and almost impossible to break with the high speed that generates, IS VERY IMPORTANT TO PROTECT THE COPPER PIPE WITH PLASTIC RESIN INSIDE, in this way the magnets never move, i have experience at the moment with 35,000-39,000 RPM with this system, and never have a problem.
I decided to built the "MAGLEV WINDOW MOTOR" because i have double protection, the shaft and the rotor protect me in case brake some magnet, because i have a box with wire around of the rotor.
Other thing is important to build a "PERFECT ROTOR" you can see my videos, i HAVE A PERFECT ROTOR, this generates greater efficiency and better control engine rotation almost perfect, i have very good results with this sytem.
saludos...jorge
joefree
hola Jorge
podrias enviarme el circuito que te comente
el quadrifilar pancake coil que entraba en resonancia
y encendia una buena cantidad de leds
con unas pequeñas baterias
y  tambien recuperabas la BEMF enciendo mas leds
.............o el que te haya funcionando mejor para poner en resonancia las pancakes
gracias y saludos
