Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
skycollection
La marca de los supercapacitores es NESSCAP y la especificacion es 2.7V-25F estos capacitores me fueron enviados de Estados Unidos por una persona amable, yo los he encontrado en EBAY con diferentes precios y especificaciones, a mi me pasa lo mismo, el flete es demasiado caro, mas de lo que vale el producto. pero esto es asi, no hay de otra, o los compras o nunca vas a saber lo que puedes hacer con varios experimentos que puedes hacer, en mi video tengo 3 bulbos de leds que duran encendidos en "self oscillation" por mas de 4 minutos con los supercapacitores, asi no gastas tanto las baterias, el supercapacitor se carga muy rapido. Saludos Jorge.
MagnaProp
Quote from: skycollection on October 04, 2015, 04:45:55 PM
With this four series of videos tutorial i finish my project "pancake multifilar coils" i hope it help for someone...!
Excelente! Thanks for doing the videos.
skycollection
https://www.youtube.com/watch?v=nFbv-_wd2Pw
With this video i can show you one of the hundreds experiments you can do with pancake coils ...!
synchro1
@Jorge,
Something for your consideration:
The "Tesla Bifilar Coil" was first patented as an A.C. electromagnet by Nicola Tesla. Below is a picture of an A.C. Reed Switch:
An "Iron Rotor" would be attracted to an energized A.C. Bifilar Electromagnet Coil. The A.C. Reed Switch could run in series with A.C. wall current. A tiny trigger magnet would  need to be positioned on the iron rotor to close the Reed Switch. A.C. current would make a magnet rotor oscillate, but Ferrite would be attracted equally to both alternating poles. A very efficient "Attraction Motor" should result from your super powerful pulsed A.C. "Multifilar Pancake Coils"!
synchro1
Ferrite rotor permeability is a critical factor; The lower the magnetic remnance, the higher the R.P.M.. Saturation control is related to speed and power. Higher perm ferrite rotor plugs can deliver higher speed along with increased torque without ever slowing down.
An A.C. bulb would be needed to harvest the BEMF.
