Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
synchro1
What's unique about Skycollection's oscillator induction alternator is that we can increase voltage but not amperage, as Gerard Morin points out. This imparts a singular advantage to Skycollection's system! This proves that Jorge's invention is a legitimate energy amplifier and may indeed lead to a self sustaining photon reactor!
A bedini SSG would speed the neo sphere up a thousand times to 50K along with the voltage. We could string LED's to the Moon with the same amperage consumption! The system's dividing the voltage and sharing the amperage. This system will definitely self loop with the LED's inside photovoltaic recovery box's; Still not violating any laws. A high voltage generator more then just a transformer, coupled with a transformer. The load functions as the "Step down" portion! The losses normally associated with step down are directly transformed into power; Once again, "Lenz's Law" evaded a second time and Overunity in sight! We just need to tailor the load or number of coil lights in advance to the voltage we generate to avoid burning the bulbs out. Time to pop the corks! Quantum leap override! Jorge cheats "Lenz's Law" twice; Once in the pickup stage and again in the high voltage step down!
        "All Aboard"!
synchro1
Quote from: Atommix93rdAtom1 on November 11, 2015, 02:15:37 PM
A self running photon reactor but the inventor has said the amps drop as more bulbs are added ? Voltage and high frequency would light the bulbs but its not a generator in the normal term of the word it becomes an oscillator for electrons thats stimulating  photon emission .  The sustain in terms of a constant at 0. will require energy ! From 8 mints to 8 years is a very big leap with out energy haha it would be best to negatively charge the coils prior to switching the device on and use a geometric harmonic formula for the construct of the coils ! Than is a free energy generator and can power a house.... Its all been done !!! many times !!! What I like about it is its small light weight cheep simple clean safe ! What I don't like about it is that it needs that extra bit of quantum alinement and that now puts it into a vulnerable position over its development and its intellectual property ect ... !
I have a free energy 12kwh system but its a bit heavy but cheap and safe ! I don't use coils or sparks and static or high frequency !
If we can do a deal than you get the negative coils electron propagator and a chance to protect the IP ! Don't leave this at LED lights you have to go all the way to zero point mass energy production on the scale up of the designe ....
@Atommix93rdAtom1,
What I understood "Skycollection" to say is that the run down time on the one bulb is the same as the five bulbs, and that the five bulbs divide the voltage. The same run time indicates the amperage is the same. Let's say he measures 100 volts to the one bulb, he's going to measure 20 volts on each of the five bulbs, but the amperage has to be same if the capacitors are equally charged and the run times are equal. One amp to the 100 volts bulb equals 100 watts: One amp to the five bulbs at 20 volts is also 100 watts.
Where did you see "Skycollection" say that the amperage drops? ha,ha. If you can't cite a source then just go away, you sound like a crank!
synchro1
Quote from: Atommix93rdAtom1 on November 11, 2015, 03:17:33 PM
The only crank is in your negative head ! I was responding to what you said ! Its your daft claim that mentioned a line of
lED s to the moon you dumb daft twat .... Insults ???? Thats a empty brain full of crap son !!!
Now go light your bulbs all the way to the moon with no drop in amps  ! And learn to read your own words !
But the envy in you will now eat what is left of your brain and that wont take to long ....... hahaha idiot !
@Atommix93rdAtom1,
You dumb daft twat. Thats a empty brain full of crap son. Eat what is left of your brain. hahaha idiot !
That's some pretty good English! We know about "Black Ops disinformation Shills" on this Forum Pal!
Here's a quote from you; You lying sack of shit:
"The inventor has said the amps drop as more bulbs are added".
Then you turn around and say:
"I was responding to what you said".
synchro1
Quote from: Atommix93rdAtom1 on November 11, 2015, 05:36:45 PM
No you said that !!!
Any way read the message I sent you !!! if you can !!! black opps ???? wtf ???? this is not 1956 I don't do politics But I do build space craft ....... what do you build ? the book of insults hahahahh now take up the challenge I sent you and shut up and get on with it ......... don't hide away from what you fear ! you don't know what a negative charge coil is do you !
But you do know about crop circles and lsd hahahahahhaha don't worry son I am here now !!! And that means I cook the dinner in a soup of magical logic !!! And your head will be required as a cup washed out and made ready for the soup to be pored into .... Don't worry it wont hurt much but if your lucky it might re grow the last brain cell that you got left ........ Now take up the challenge son ..........
Fuck you!
synchro1
Quote from: Atommix93rdAtom1 on November 11, 2015, 06:09:35 PM
GROW UP SON THAN TURN INTO A FLOWER ! FLOWER POWER IS THE ONLY POWER YOU WILL EVER MAKE !!!
@Atommix93rdAtom1,
Get off this thread! I started this thread. You've been off topic the entire time trying to sell some kind of "Bogus Crap". Start your own thread.
                                                 Stop misrepresenting the inventor's test results!
