Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
skycollection
Thanks Synchro1, it´s possible to make pancake coils but i need a lot of money to start a company.......the pancake coils have potential overunity and i will make the process soon, i hope. About the oscilloscope is the first time that  i connect this device, i don´t know how to use it, but i hope it serves the information i presented in this video.
skycollection
About the leds turned on........sometimes happens tha the leds turned on by switch alone without the magnet rotor, but not all time, sometimes i need to move the rotor to start "self oscillation" i did many times the test and 4 of 9 truned on and 5 needs to move the magnet. I am looking some way to start on without the help of the magnets, but this is "investigation" that takes time, i will make it soon.
Void
Quote from: skycollection on March 05, 2015, 02:25:26 PM
Hi skycollection. What are you using to power the circuit in your last video?
If you power from a battery, how much current is drawn from the battery to
power the circuit when you are light all those LEDs? Are you using 3 volts?
All the best...
Jorge:
The simple truth is that you are making a transformer with one primary and multiple secondaries.  If you took a toroidal ferrite core, and made your own primary and secondary windings and connected up your LEDs you would get the same or better results.  Most likely you would get better results because the coupling between the primary and the multiple secondaries would be much better.  I am assuming that any power losses in the core will be much much less than the power that goes into your LED loads.
Have fun with your experimenting.  I encourage to experiment.  But it would be a mistake to believe that you are doing something different or unique or doing something that might be over unity.  You are simply making a multi-tap air core transformer by putting several pancake coils inside the plastic tube.
I am really not sure if a multi-tap toroidal ferrite core transformer would give you better results than your multi-tap air core transformer based on your pancake coils.  The real way to find out would be to make precision power-in and power out measurements for both configurations using a digital storage oscilloscope.
However, you could make a pretty good alternative measurement by driving the primary with a pure sine wave from an audio amplifier and changing the LED lights for load resistors.  If you did that then you could make precision power-in and power-out measurements with your oscilloscope or a good quality true-RMS multimeter.  You could make the precision measurements on the pancake coil transformer and the toroidal core transformer like this and compare the two setups for their power-in vs. total power out efficiency.  That would at least give you some data that would indicate which of the two transformer configurations gives you better performance for a sine wave input and driving multiple resistive loads.
I will repeat, I encourage you to experiment.  If you don't want to make measurements that's fine and that your choice.  But you have to be realistic and understand what you are dong and have reasonable and realistic expectations for your results.
skycollection
Void, in this experiment i used three AA batteries, and i can use the supercaps with the same result, but the supercpas needs to charge every 4 minutes, i am implementing the system to charge the supercaps "in series" in less time with a SIX VOLTS BATTERY in less time and disconnect the supercapas to avoid to overload, soon i will make the video on youtube.
