Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
skycollection
Thanks VOID, I made the comparison LED bulb brightness with a 12-volts battery, and with my vivrator circuit, using only one 12 volts bulb led and the result was impressive....! I almost reached the brightness LED bulb with a battery of 12 volts and my pancake coil, I would say 90% of brilliance, i was thinking in build a joule thief and connect to the led bulb and see what happens.
I have a "rare effect" with the circuit, i check all the connections and i don´t have false contact, the rare effect consist in place my hand above the circuit and i have an "interference" that swicht off the bulb leds,
I have always seen that there are many things unknown in my pancake coils, this effect is like radio waves that they do "ground" with my hand, i was thinking in build a special bi-filar pancake coil and use only one bulb of leds, i think i can make a practical application with my pancake coils.
I really apreciate all your commentaries and i will continue with more experiments and i hope get the goal...!
Void
Quote from: skycollection on March 08, 2015, 10:43:16 PM
I have a "rare effect" with the circuit, i check all the connections and i don´t have false contact, the rare effect consist in place my hand above the circuit and i have an "interference" that swicht off the bulb leds, I have always seen that there are many things unknown in my pancake coils, this effect is like radio waves that they do "ground" with my hand, i was thinking in build a special bi-filar pancake coil and use only one bulb of leds, i think i can make a practical application with my pancake coils.
Hi Skycollection.  If your LED bulb with your pancake coil circuit is somewhere close to the brightness
of the LED bulb when the LED bulb is connected to a 12V battery, then that is quite impressive.
If one or more of your pancake coils are running close to or at a resonance frequency, then when you place your
hand near the coils you can untune the coils and cause them to move away from their resonance frequency. This happens
because your body has capacitance and when you move your hand or body close to the coils your body capacitance
interacts with the coils and changes their resonant frequency, or to say it another way,  it changes the tuning of the coils.
You are altering the capacitance of the coil assembly when you move your hand close to the coils. This same effect occurs with
any coils that are run at or close to a resonance frequency. It seems that one or more of your coils may be running at or near a resonance frequency.
All the best...
skycollection
Void, i did another test with other bi-filar pancake coil and in accordance with the resistance ohms is the result, for example, other pancake coil was:input voltage= 5.02 volts x 0.27 = 1.35 watts the led bulb of 12 volts i am using is of three watts. IS POSSIBLE THAT MY PANCAKE COILS, TRI-FILAR, CUADRIFILAR, PENTAFILAR AND SEPTEFILAR COILS, HAVE LOW RESISTANCE OHMS, and is difficult that the bulb leds swith on correctly or with all its intensity ...!
Any way is an interesting project that leaves me a good experience....!
Void
Quote from: skycollection on March 09, 2015, 11:58:29 AM
Hi Skycollection. I am not sure what you mean, as the resistance of the pancake coil is not really much of
a factor in the input power consumption of your entire circuit (your driver circuit plus the coils plus the LED bulbs).
Do you mean that while your circuit was running with the LED bulbs also connected and lighting up, that the
input power consumption was around 1.35 Watts? Just to confirm, you understand that you have to measure the input
power with the driver circuit running and the LED bulbs connected and lighting up? This is what you did?
All the best...
