Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
synchro1
Quote from: mscoffman on February 25, 2015, 04:41:22 PM
Remember;
Overunity is accomplished by impedance matching.
Any light is wasted energy.
One way to collect the energy is small audio transformers or toroids followed by bridge rectifiers and a filter cap and matching load resistors.
The filter suppresses the AC pulse energy to DC and the transformers blocks interaction between stages. This would be followed by
an efficient DC to DC converter and removal of load resistors.
:S:MarkSCoffman
@MarkSCoffman,
A fast switching Shotky diode from the positive output coil lead in series directly to the positive leg of a storage capacitor and the negative leads connected to each other is all it would take to rectify and store the output current.
Paul-R
What I like,where possible, is a resistive load plunged into water whose temperature rise is measured. Nobody can argue with that, particularly if you get the right value for the specific heat.
synchro1
What's the frequency that the "Pentafilar's" ringing at?  "Maximum frequency is 250 MHz for the 2N2222". Perhaps the "Pentafilar Primary" may be considered as Broadcasting Power, encountering zero resistance. Might it be a radio? It sounds like a radio!
The spinning magnet generates a sine wave that triggers the "Complentary Transistors"; Then they continue to trigger from cascading feedback untill they rise to their maximun switch rate nearly instantaneously.
"When radio waves strike an electrical conductor, the oscillating fields induce an alternating current in the conductor".
Is the "Pentafilar Primary" broadcasting radio waves? Is it a "Marconi Set"? Can the output coil be viewed as a reciever and new broadcasting antenna? A series of radio wave repeaters? Is it posible to actually "Multipy Power" this way?
Vortex1
Quote from: synchro1 on February 24, 2015, 11:19:45 PM
Skycollection's "Complementary Transistors" are driving current in both directions through the primary pancake coil! Jorge calls this "Singing Oscillation "The Swing".
"Two different types of transistors "PNP" and "NPN", can be a great advantage when designing power amplifier circuits such as the Class B Amplifier".
Class-B amplifiers uses "Complementary" or "Matched Pair" (that is one PNP and one NPN connected together) transistors in its output stage or in reversible H-Bridge motor control circuits were we want to control the flow of current evenly through the motor in both directions.
A pair of corresponding NPN and PNP transistors with near identical characteristics to each other are called "Complementary Transistors" such as the 2N3906 PNP and the 2N2222 NPN Skycollection's using.
Also, class B amplifiers use complementary NPN and PNP in their power output stage design. The NPN transistor conducts for only the positive half of the signal while the PNP transistor conducts for negative half of the signal.
This allows the amplifier to "drive the required power in both directions" at the stated nominal impedance and power resulting in an output current which is likely to be in the order of several amps shared evenly between the two complementary transistors.
Skycollection shows his circuit schematic at 1:05 in this video:
https://www.youtube.com/watch?v=QY9TjsGccM4
I think rather than a class B push pull drive, the circuit is more in the arrangement of a regenerative latch circuit with the 2n2222 doing the hard switching. Examine the current path, the 2n3906 current is severely limited by the 1K. Nevertheless it is a novel circuit arrangement.
synchro1
@Vortex1,
Thanks for uploading Skycollection's schematic. Do you think the circuit's broadcasting in the RF range?
