Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
synchro1
Quote from: MileHigh on March 31, 2015, 12:24:45 AM
"Causing trouble" is your code word for when you are not capable of making a logical argument.
From Arthurs:
@Milehigh,
The "Series Bifilar Coil" of Nicola Tesla is an AC coil. The coil has zero impedance to change in current direction. Running AC current through a "Single Wire" coil of equal Ohmic resistance will cause it to heat up while the "Bifilar" runs cool. Testing the two types of coils for comparison with a monopolar rotor or DC current will not produce any meaningful results.
skycollection
I post this video and the circuit for my pancake coils and a pulse motor-generator with 2 AA batteries...!
https://www.youtube.com/watch?v=do5xtmfMRxI
synchro1
Arthurs
Hi skycollection
Thank you very much guidance
I will follow you provide coil wiring diagram to continue to do the experiment,
All coils no clockwise or counterclockwise settings?
Or there is nothing "secret" technique?
My email: arthurs630514@hotmail.com
Arthurs
Use "AA" batteries as a power source,
Does not explain the weak supply capacity,
For example: DURACELL "AA" battery capacity can reach more than 1700mAh,
So: Use "AA" batteries as the drive power can not explain the input power is small.
Thus: To know the exact input power,
Must be connected to the meter drive circuit monitors the input voltage and current.
