Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
synchro1
Quote from: skycollection on April 06, 2015, 12:31:59 AM
CONCLUSION: WITH A PANCAKE COIL IS POSSIBLE TO DELAY THE LENZ EFFECT, I PRESENT THIS EXPERIMENT AND IS MY NEW PANCAKE COIL WITH MICRO-MAGNETS INSIDE, THIS PANCAKE COIL IS A POWERFUL COIL....!
https://www.youtube.com/watch?v=BI95N4D372o
@Skycollection,
I successfully looped a magnet core bifilar coil back to source and charged the run battery over five years ago. I bet yours would do at least as well. Nice work!
skycollection
This is a new experiment with the TESLA 2, QUADRIFILAR PANCAKE COIL, i have eliminated the bedini circuit and i am trying with the circuit JL94, the results change dramatically...!
https://www.youtube.com/watch?v=NktNzbMkres
skycollection
THE TRUTH NEVER LIES............!
DaKrampus[/b] [/color]Hace 2 horas[/color]
very impressive... BUT i think there is an error.. its not in and out "Voltage"  the meters are showing but its, i think, the in and out amperage... (if i know those meters). would be interesting to have the in and out voltage also..
Is the first commentary in my last video....!
DaKrampus
@Skycollection
Hi
and sorry if there was a misunderstanding!
Yes it was me commenting that video...
I was NOT saying that there was a LIE in what i was seeing..
I was referring to the text that was in the video
at 8 seconds (of the 51  seconds video)
it says : input voltage over the left meter and output voltage over the right meter.
left meter displays: 0.16 and the right meter displays: 0.15
which are 160 and 150 milliamps. You can also see on the meters that they are set to 10 amps.
so what i meant is: I wanted to draw your attention to the fact that there was probably a typo, a small mistake, in the video insert, it should say for example input power and output power or something similar over the meters instead of voltage.
Because it is definitely NOT 0.16 volts (as the meter is set to amps)
that is all!!! I did not mean to say that the video is not true!!!!
I also remarked that it would be interesting to have the voltage in and out, so that we could calculate the watts and compare input to output in watts.
I have been admiring your work and craftmanship a lot for a long time and would NEVER consider your work being a lie!!!!
I hope you understand what I meen, as english is not my mother tongue.
See you soon
Luc
skycollection
Milehigh, you ask me if the pancake coil inside of a permanent magnetic field is good or bad, now i can answer you that is a "window" or is the way to eliminate in some porcentsage %, no matter how much, is important to delay the LENZ EFFECT, i have a video in wich i can accelerate the magnet rotor under load. I have in process a new pancake coil (bi-filar pancake coil) inside of a strong permanent magnetic field...!
very soon...! (not micro-magnets)...!
