Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
synchro1
A preliminary test could be easily performed with a twelve volt battery. Skycollection should be able to light twenty "Pancake Coil LED'S" just as brightly as his videos', off his 12 volt lead acid battery; I believe his 2N2222 NPN and 2N3906 PNP amplifying transistors can definitely handle the higher voltage.
The kind of D.C. to D.C. voltage doubler circuit schematic I uploaded above can handle wider ranges more efficiently either from "Super Capacitors" or batteries without getting clumsy.
        "The Ventifilar"?
synchro1
Skycollection would need at least 3 or 4 of these 10F 2.5 volt Super Capacitors in series to safely operate at 5 volts:
seychelles
TO MAKE THIS A SELF RUNNER IS TO GET RID OF THREE OF THESE LIGHTS AND
COUPLE THEIR RECTIFIED OUTPUT TO CHARGE THE SUPER CAP.
seychelles
BY THE JORGE YOU ARE THE BEST AND I KNOW WITHOUT A DOUBT THAT YOU
WILL FINALLY INVENT YOUR FREE ENERGY MACHINE. KEEP UP YOUR GREAT WORK
AND THANK YOU FOR SHARING. GOD BLESS.
skycollection
I would like to send the septefilar pancake coil to a good laboratory, i think is not complete the analisys, i have no technological instruments at home, i never said that is a selfrunner generator or a overunity generator, i need the test of the best lab, and second that everybody make it at home, i will post the way to construct step by step the septefilar pancake coil, or the "pentafilar pancake coil" or the quadrifilar pancake coil dpending you need...!
I would like to send the pancake coil for example to JL NAUDIN LABS, or other lab that want to test my invent...!
saludos
jorge rebolledo
