E-Trike Kick Starter Project.
Started by TommeyLReed, February 27, 2015, 04:59:28 PM
TommeyLReed
Hi Chet,
Yes I built a few recumbent in the past, I will look for a picture and put it up on this site.
Tom.
TommeyLReed
Hi Telecom,
I was thinking of aluminum frame.
I will have to make a prototype frame from plywood and double check all parts before going all aluminum.
Plywood will allow me to make a basic template and also I will be able to correct design before a finish design frame.
Tom
TommeyLReed
Hi All,
Got a few parts already to start the frame design, will make it out of laminated wood to test run this design.
https://www.youtube.com/channel/UCK3k2-Vhr19mtUqm42N687Q
Tom
MarkE
It looks nicely stiff in the Z axis, but I don't see what provides stiffness in the X axis.  Are you relying on the thickness of the material for that?  You might want to consider using square or round tubing along the top and bottom of your horizontal members so that they do not require excess material for the desired stiffness.
TommeyLReed
Hi MarkE,
I will be able to test the frame and make correction as need.
https://www.youtube.com/watch?v=HimcaUKzqxU&feature=youtu.be
Tom
