Switchable Magnets.
Started by synchro1, May 05, 2015, 11:45:59 AM
synchro1
Here's a video on drilling holes in "Pyrex" with the Porsadrill diamond bit system. A "T" coupling can be added to a cooler recycling tube to replenish water to the outermost boiler. This setup can be turned into a fine piece of laboratory equipment with a few simple modifications. Naturally a thermostat needs to be positioned inside the boiler away from the heating element and cooling inlet and connected to the temperature controller. (See below):
https://www.youtube.com/watch?v=FPY7k9dkI8g
Below: Amazon.
Product Details
2pc DIAMOND HOLE SAW - CORE DRILL - Set - 1/2" + 1"
by Unknown
$5.01
synchro1
PT100 type Thermocouple Sensor for Temperature Controller. This is a 2m (6.6ft) water resistant (submersible) RTD PT-100 type thermocouple. It provides "0.1 degree" resolution and works well with most digital temperature control units. $16.00!
synchro1
norman6538
Quote from: synchro1 on April 12, 2017, 06:55:04 PM
Take a look at this design for a magnet switch:
https://www.youtube.com/watch?v=e6kWy5yCOGs
Thanks, that is very nice but probably would not have net usable work out
over the input work to twist the setup....
But  it could trigger something further..
Norman
synchro1
Quote from: norman6538 on April 12, 2017, 07:53:55 PM
Norman
@Norman,
Check this graph out: The Shear to Push Pull Force is 1 to 3.33:
