Capillarity engine?
Started by Gabriele, May 30, 2015, 01:13:03 PM
Gabriele
Low-Q
Quote from: Gabriele on May 30, 2015, 01:13:03 PM
Hello.After Glass sheets are submerged we separe them and restart the cycle. What do you think? Someone with metods to calcolate energy obtained and spent?
The calculus is simple: Energy spent - energy out = 0
The capillary effect does not behave as WE want it to, but how the NATURE want it to. So this effect applies in both ends of a capillary tube or plates, and does not work in only one direction.
Using magnetism does not change anything.
Vidar
RomanEmpire
This could help, not perfectly in theme, but I think it can be an inspiration
https://www.youtube.com/watch?v=JXKM6D9rPis
Gabriele
If you want i'm onest,i didn't calculated with precision the energy needed to separate glass walls. I'm sure if we have the situation rappresented in first picture(not me :p) we have to admit vertical forces are different for each situation. Understand that we don't have ties between two glass walls with anti-adeshive surface,i supponce underwater we can put the two very thin glasses in orizzontal situation near surface and win to separate them only a very little force. With 2, 1cmx1cmx100cm glasses we obtain 0,2gx100cm and at a deep of 1mm to separate them for an half of centimeter 0,1g x100cmx distance (0,5). I remember you that when we separate the two plates water run inside generating energy. And we can also add surfactants to amplify the force will act on two glass objects.
