Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
guest1289
Could the cables be draining-off unwanted eddy currents
    -   I think someone already mentioned it on this page,  they typed
Quote"flux canceling methods?"
    (  And a far-fetched suggestion,  could there have been a technical mis-interpretation by the media-reporters,  and that 'Luling' actually meant that his device did actually receive some electrical input,  and that he claimed that his device out-putted more than it received  )
guest1289
There were a lot of cables easily visible in plain sight.
If it may of been a hoax, the designer doesn't seem like a careless type, he would have hidden them .
  Assuming it wasn't a hoax
    -  There may have been electrical-input,  and it may have been a method to  neutralize the permanent-magnets,  or the metals, through induction, or direct contact .
    -  Of course, maybe there was no electrical-input,  and the cables were either feeding generated current back into the motor,  or,  it was the performance-monitoring system
    -  Could the cables maybe not be carrying electricity, could they be intended to carry  'magnetic-current',  as part of the  'neutralization'  of the permanent-magnets,  or the metals.
        What happens if you use metals or cables,  to join the S-pole of a magnet to it's N-pole, but I assume you'd need thicker cables .
    But there is a lot of weight providing momentum, maybe his design was so finely tuned to maximize the momentum effect,  that that could have made his device function successfully,  with, or without the above detailed possibilities .
guest1289
  Somehow I think this was an actually functioning   Self-Running-Permanent-Magnet-Motor  .
    You just manually turned it initially,  it generated some current to power the magnetic-shielding-mechanism,  and then it just kept going by itself.
    (  I wonder if the inventor was the first to think of it,  because it's the kind of very logical,  basic,  and simple idea that would have been invented even before  ' Luling'  )
    (  There was an identical? motor presented in 2013?( 2014? ) by someone from the same country,  coincidence ? ,  and I think the site-administrator actually visited the person that presented that motor  )
    This would be a great one to reproduce today( unless the one in  2013?( 2014? ) is identical.
       Maybe it would be easier( for anyone wanting to try ) to do by using your own design,  while still basing it on the same principle.
Liberty
Quote from: MagnaProp on January 12, 2016, 03:07:02 PM
Thanks for the info and your thoughts on the device are interesting.
Hope I didn't turn people off from investigating this device by pointing out the parts that look electric. TinMan and others have already shown that magnets can do useful work. If this device found a way to only sip electricity while being powered by mainly permanent magnets, it would be a steep in the right direction indeed.
With the "Power Assisted Magnet Motor" that I announced a little while ago in the news section, the book proposes using short pulses of electricity while the motor torque is being produced by permanent magnets.  That is exactly what the "Power Assisted Magnet Motor" is capable of doing.  It's not just a "step in the right direction", but is how to very efficiently run a magnet motor.
Liberty
Liberty
guest1289
Quote from: Liberty on August 20, 2016, 11:18:21 PM
Liberty
    That could double or  much  more,   the range ( mileage ) of electric-cars .
    (  What about the torque of the motor you mention,  it must have some limitations, even though you said  "motor torque is being produced by permanent magnets"   )
   (  I assume this type of motor would need a much greater amount of permanent-magnets,  higher-cost,  weight  )
        -  Is this the same thing as  'Pulse-Motors'  which are regularly discussed on this site .
           (  I wonder if fine-control via input-current,  is an issue  )
           Start a thread,  website,  youtube-channel
