Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
norman6538
Quote from: rstergar on December 31, 2017, 10:43:35 AM
Thank you :)
But this model will not work because I must start over and create it more precise and with better materials than plastic...
Here is my new idea of design: https://youtu.be/oAvcmSFOfns
I will start ASAP...will update here ;)
Regarding the animation - how do you keep the metal from getting stuck at the magnet?
Norman
dom444
It  has been a while since i did the research on this motor the force holding the metal blocks when near the magnet  is not strong using my hand i successfully  could make the motor spin easy when rocking the blocks back and forward on the magnets with the model i made,  the difficulty is with the cam system getting it right, i still think it can work but have been to busy to do any work on it lately its timing and the materials used that are important.
Low-Q
Quote from: dom444 on June 19, 2018, 06:45:56 PM
It is very hard, if not impossible, to determine the energy you spend with your hands to make this motor going.
A weak magnet, and with a motor without load, you will barely feel any counterwork done on your hand.
Using a cam system will most probably cause the weak motor to stop. The easiest explanation why it will stop is because magnetism isn't energy. It's just a force.
Vidar
dom444
you are wrong there my model is made of solid steel and welded nearly lost a finger tip as the force of the rotor approaches the magnets there is real force and not just a bit as i said problem  is the timing.i used neodymium magnets x2 on each face when it is near the face of the rotor  you cant stop it it is not a kids motor, and mine is only small imagine a big one.
I used steel because its all i had but what i really want is cast iron for the rotor plates i can't find any hear where i am as it adds even more to the attraction force when you get serious about building this motor
there are real forces involved and you have to be careful with it.
truesearch
@dmo444
I'd be interested to learn more about your magnet-motor research. Would you be willing to share some pictures of what you are doing?
truesearch
