new magnet motor idea
Started by rstergar, July 16, 2015, 04:33:58 PM
lumen
All vectors will always point to the center under all conditions, but it's the combined vectors between the solid frame and moveable points and centrifugal force that can change the final force vector direction.
If you start with only two magnets around the ring magnet, the center (repel) and the outer (attract) the system is balanced. If this system is pulled to the side from the center point, it will want to rotate, but it's the direction it rotates that is important and it's not in the direction one might think.
One might think that the outer attracting magnet would rotate to get closer to the ring magnet but in fact the pulling vector to the center is much stronger, and as the ring magnet increases in diameter the desire for the attracting cylinder to rotate becomes less and the pull to the center becomes greater.
It's just an idea, but when one thinks of it as using springs and rollers to achieve the same process, it appears more impossible.  Gravity?
MagnaProp
Quote from: lumen on July 18, 2015, 04:53:24 PM
...If this system is pulled to the side from the center point, it will want to rotate...
Can you draw the lines of force for me? I don't understand why it would rotate.
rstergar
quick update on this idea  :)
two cylinders helping each other to get through sticky point...
and a new drawing with closed system and numbered parts...
hope i will get 3D printer soon and try to make one and test it 8)
https://youtu.be/WRt0RgDBxuw
freddyfeeuerstein
Hi together,
looks nice. Havn't seen like this before. I also do some research on magnet motors/gernerators. Some days ago i posted a new topic but it still needs to apply by an moderator :/ so it hangs somewhere in the nirvana :)
I am not going to write all the text again, but check this link:
http://open-source-energy.org/?topic=2506.msg34036
For people how can't see the picture, go to:
https://community.conrad.de/startup-innovation-ansehen/neues-konzept-eines-energie-generators
rstergar
almost done ...thanks to 3D printing :)
