TinMan Generator Research Moderated Topic
Started by gotoluc, July 19, 2015, 10:49:03 PM
ramset
TinMan
I personally have a big problem with big bore Noisy fire breathing V8's
It calls to some very dark side of me that turns me into a raving lunatic ....
Bliss...
thx
PS to Syncro
Chill on the Tinsel Taunts
Thanks Grandma
synchro1
"Electrical circuits in plasmas store inductive (magnetic) energy, and should the circuit be disrupted, for example, by a plasma instability, the inductive energy will be released as plasma heating and acceleration".
The "Magnetic Plasma Field" can generate enough current when disrupted to cause rotor acceleration!
Tinman pushes his motor r.p.m. deep into the red line with a few modifications. He may cause enough electrical arcing to get a power boost from magnetic plasma.
Void
Quote from: seychelles on July 27, 2015, 09:51:51 AM
Anyway my small contribution..
https://www.youtube.com/watch?v=rz0wPIhGFk8&amp=&feature=youtube_gdata_player
Hi Seychelles. Not that it matters too much for your demo, but I think the first current reading was around 3A,
and the second current reading after switching the diode direction was around 2A. Each little division on
your DC ammeter is 0.5A. So the current draw dropped by about 1A after switching the diode direction. :)
All the best...
seychelles
void thanks for the correction. these brushes are tilted to aprox 45 degrees ..mind you
this motor is unmodified.. so an increase in efficiency when the rotor is rotating against
the brushes..but then again it is all here say..one have to put a lot of things into context.
1 the rev of the motor 2 torque of the rotor. 3 current used.
