TinMan Generator Research Moderated Topic
Started by gotoluc, July 19, 2015, 10:49:03 PM
Jimboot
I think we're all busy at the bench. I know I am :)
gotoluc
Quote from: Magluvin on August 06, 2015, 11:13:05 PM
Seems like this topic died. What happened?
Mags
I'm still working at it but noting new to share and it looks like TinMan is also working hard at it but sometimes things don't work out.
https://www.youtube.com/watch?v=VhupY3D8Fwg&feature=em-subs_digest
Luc
Magluvin
Ive seen motor windings with waxed string to hold the bundles tight. Could be used to tie down loose ends. Used it at a company I used to work for Union Switch and Signal to tie wire bundles in rail road and subway switch boxes.  But the string was only for during the bundling then tie wrapped and strings removed.
Once you tie the knot, it wont come loose on its own.
There are hot glue sticks that are higher temp and harder when cool.  I use the hard for most things. Guys in car audio ind hot glue tweeters and panels using the softer sticks and the sun is enough to let it loose.
Mags
Jimboot
I pulled apart a small DC motor only to find it only had 3 rotor segments DOH! Can't really re-wire that. Pulling apart a power saw this weekend. Getting a commutator for the opposite end may be a be of fun though. May have to rig something up.
tinman
Sorry guys-im out.
All this talk about patents,Aaron the rookie,peter lindermann-->just go's to show how easy it is to take some one elses work and get a patent on it.
I can see it now.
The secrets of the rotary transformer-$39.95.
Brad
