TinMan Generator Research Moderated Topic
Started by gotoluc, July 19, 2015, 10:49:03 PM
synchro1
tinman
Quote from: Jimboot on July 22, 2015, 08:19:56 AM
Thanks brad really cleared a few things up. I'll be pursuing both projects as well. Mght have to win a couple of poker nights to pick up the rigol :) grum and I are working on the same motor which doesn't lend itself to that sort of brush adjustment. Can you confirm what Penna has said? At this stage I'm thinking I'll have to look for a different Motor... And explain the deconstructed Dyson to my wife :)
The tipping of the brushes is to adjust the timing,and also to have two rotor segments in contact at once. This eliminates most of the arcing of the brushes,and reduces losses by way of heat. It also allows for the reversing of the magnetic field created by the stator coils to that of the rotors field.
See this video(if you havnt yet) of my early experiments,and you can see how much more efficient the standard RT is than an !off the shelf! motor that was designed to drive the fan used in the test.
The standard motor on the house fan is suppose to be 86% efficient minimum,but for arguments sake,lets say it is only 80% efficient. The RT is 40%+ more efficient at running the fan blade than the motor that was designed to do the job. Only 1 stator coil is being used on the RT at the time this video was made,as it was early days-as you will be able to tell with some of the descriptions i give lol.
https://www.youtube.com/watch?v=szpJ97M58G4
tinman
Quote from: synchro1 on July 22, 2015, 08:57:00 AM
Here's a cool "Magnetic Amplification" video:
https://www.youtube.com/watch?v=sxrJoGZy1to
How is this magnetic amplification?
In fact,how is this anything at all. I see a pulse motor with biased coil's-i see nothing else.
poynt99
Quote from: tinman on July 22, 2015, 09:03:33 AM
As opposed to 4 rotor segments?
synchro1
Quote from: tinman on July 22, 2015, 09:06:36 AM
A switched polarity could deliver twice the repulsion followed by a neutralization pulse. The same pole switch circuit could power a coil charged rotor with 2500gm to 1/2 watt ratio, with very powerful magnet stators.
