This Guy Converted His Motorcycle To Run On Water
Started by joel321, July 27, 2015, 12:38:00 AM
gravityblock
Quote from: Paul-R on July 27, 2015, 10:05:38 AM
When I saw this thread, I thought the ever entertaining Guy Martin had finally cracked it:
https://www.youtube.com/watch?v=fZFoaNHDMok
Great stuff!
McLean V-8 Monocycle (Crash 2:55)  <-------Not running on water, but is a motorcycle converted to run inside a wheel and is a good laugh.
Gravock
gravityblock
Quote from: madama on July 27, 2015, 03:35:45 PM
guys
anyone have a realistic/economic way to make an electricity generator running on hydrogen produced on spot?
it seems that s the guy is doing with his motorcycle
any ideas? or any commercial solution we could adapt with a generator?
Why use a battery to convert water to hydrogen when the conversion process is less than 100% efficeient?  You can run the motorcycle directly from a battery without the losses associated with hydrogen production from electricity.  Then you can use a solar panel to recharge the battery.  The Zero S electric motorcycle could be the beginning of the end to gas powered motorcycles.
Gravock
gravityblock
Quote from: madama on July 27, 2015, 04:16:57 PM
solar can t generate electricity 24/7
this is the only and main issue
All you need is additional batteries that were previously charged during the times that solar energy was generating electricity.  Unless you're riding the motorcycle 24/7, then you don't need solar to generate electricity 24/7 for your motorcycle as you would for your home.
Gravock
NTesla
The issue is not be about IF he is running his motorcycle on water - we know that is achievable. The issue is if the process of producing hydrogen is cost effective when compared to petroleum etc. What is the point of making a vehicle run on hydrogen if you have access to petroleum and its a cheaper form of energy?
