'Impossible' rocket drive works and could get to Moon in four hours
Started by Pirate88179, July 29, 2015, 01:12:10 AM
MarkE
Quote from: gravityblock on August 10, 2015, 06:44:40 AM
MarkE,
According to you, the water isn't allowed to fall and displace the screw until the screw is first released.  You're putting the effect before the cause.......and if you would put your text books to the side, then you would realize how you're putting the cart before the horse, ROFLMAO.
Gravock
LOL.
Q. What keeps the water from falling?  A. The float that as long as it is held at the bottom.
Q. When does the water start falling.  A. As soon as it can push the float upward.
gravityblock
Quote from: MarkE on August 10, 2015, 07:57:45 AM
LOL.  Ignore reality all you want. Water loses GPE, pushes on the float, the float gains KE AND GPE during the rise and ultimately loses KE.  The system loses net GPE as the center of gravity falls throughout the process.  When the process is done the float has expended all KE gained during the upward traverse, and the column has lost GPE.  You are free to dispute by showing your work.  The floats rate of ascent is initially limited by the inertia of the float and the water.  As the ascent gains speed it is further limited by viscous drag.
So, the water pushes on the float, and the float moves against the push.....<-------Good luck pushing this idea.  ROFLMAO!!!!  It is you who is ignoring reality and not me.  Another psychological projection from you.
Gravock
MarkE
Quote from: gravityblock on August 10, 2015, 08:07:38 AM
Gravock
This is all elementary text book physics you are resisting.
gravityblock
Quote from: MarkE on August 10, 2015, 08:11:33 AM
I know physics according to the text books, and I rejected those books based on bad information.  I'm not the one who is holding onto those text books and resisting from letting them go.  Can you think for yourself, or do you need someone to tell you what to think?  That's exactly what you have done.  You have given this corrupted system of things the power to do your thinking for you, and without even questioning what your being taught.  A mindless robot!  What a way to be, LOL.
Gravock
MarkE
Quote from: gravityblock on August 10, 2015, 08:19:39 AM
Gravock
If you wish to try and assert unaccepted ideas about physics then it is your burden to prove those ideas are correct.
