'Impossible' rocket drive works and could get to Moon in four hours
Started by Pirate88179, July 29, 2015, 01:12:10 AM
gravityblock
Quote from: MarkE on August 10, 2015, 08:31:54 PM
LOL, and what sets the atmospheric pressure hot shot? Oh, that would be the weight IE the gravitational force on the air.LOL.  Are you trying to compete with MM in some sort of crackpot competition?  The water and everything else in the local environment is subject to the surrounding air pressure caused by the force of gravity on the atmosphere from the local elevation on up.
Like I have said for the third time, this is similar to there being a greater force as we found in the blowing your own sail example.  And, why can't the atmospheric pressure be anti-gravity also under the right conditions?  The pressure at the bottom of the tube has a greater force pointing up than the pressure at the top of the tube that is pointing down.  Atmospheric pressure from below is a way to distinguish it from the gravitational force from above.  Call it whatever you like, but it doesn't change what it is, which is a pressure differential in this case.  You just have to get the direction of the greater force right.
Gravock
gravityblock
Actually, a vacuum, the weather, such as hurricanes, warm/cold fronts, and an ionization of the air can change the atmospheric pressure locally.  How convenient of you to leave out these other factors (this is a pattern from you).  Does this mean the gravitational force was changed or set locally by a change in atmospheric pressure Mr. Hot Shot?  LOL!
Gravock
gravityblock
If it wasn't for the vacuum, the float with the screw wouldn't rise to the top of the tube because there would be equal pressure on all sides of it.  The vacuum represents a local change in the pressure, thus we can't use the gravitational force to represent this local change in pressure.  This is common sense, and to think otherwise is to be a crackpot as MarkE is.
Gravock
MarkE
Quote from: gravityblock on August 10, 2015, 09:00:26 PM
Gravock
So what do you get if you prove yourself more of a crackpot than MM?
gravityblock
Quote from: MarkE on August 10, 2015, 09:30:57 PM
Right or wrong, I'm not looking to receive anything.  There has been a lot of famous scientists in the past who were called crack pots in their time, and they were proven to be correct many years later.  The reverse has occurred also.
Gravock
