World's first real Free Energy Flashlight - no shaking - no batteries! No Solar
Started by e2matrix, August 29, 2015, 09:01:12 PM
txt
Quote from: skywatcher on February 07, 2016, 10:40:37 AM
If it really has 120 lumen it would not be possible to operate it with only 0.14W.
Good LEDs have 100 lm/W (the best LED available has 300 lm/W) so with 0.14W it would only give about 14 lm.
Of course it is not 120 or 100 lm that it works at, except perhaps the first hour or couple of them. It is certainly much less then, though at low voltage the efficiency of LED is better than at maximal voltage, so at the current of 35mA, it can be perhaps some 30 lm even with a common LED.
Quote from: skywatcher on February 07, 2016, 10:40:37 AMAlso the calculation with 8 µW can not be correct. ...
Yes, you are perfectly right. I did a stupid calculation error - the charging would add 8.4 µWh each second, but that's irrelevant and nonsense, the charging would have to be 30mW (3*1.3V*2.6Ah => 10.14Wh / 14*24h = 30mW). Harvesting such amount of energy from the ambient EM field is already impossible, because it is simply not available unless you sit in an extremely close proximity of a strong broadcasting tower. That explains why ADGEX did not bother to put anything at all in the flashlight.
Quote from: Void on February 07, 2016, 11:11:55 AMHi txt. In the first video he showed what appears to be a different current measurement.
In the second video, could he be measuring the current after the batteries have been
run down quite a bit? I have attached a screenshot of the current measurement from the first video,
although I am not so sure at all that we can trust his measurements using that meter. :)
Yes, of course, I was speaking about the second video, where he measures the current with the multimeter. And yes, of course, the batteries were already used in that moment, so the current was lower than at the beginning. He used the analogue amperemeter just to check the digital reading.
txt
@TheCell - any news? Did you already fully discharge the flashlight in a longer run, or do you still continue in short discharges of 3hrs/day?
If you do not want to disassemble it like the Russian did, you might consider visiting the closest security checkpoint (i.e. an airport), local med lab, or a dentist, and ask them for an X-ray snapshot of the lamp - you could see whether there is anything else than just the three AA batteries and an LED, and would have the chance to ask for the refund before the time runs out.
Nink
Quote from: txt on February 09, 2016, 10:32:13 AM
I am not sure Xrays (or RF waves that you would harvest for power) can penetrate the two aluminum canisters let alone the 3 cylinders inside the torch. I know the assumption is these are 3 rechargeable AA nickle cadmium  batteries but we could give the developers the benefit of the doubt, because at this stage the 3 Cylinders could contain anything, including crystals, magnets, batteries, maybe a charging circuit (Transistor / Cap and Diode) maybe some new age tech we have never seen before etc.
I still think the best course of action is find out if you were scammed, forget the money you paid,  pull it apart and do a little forensic chemistry and post a you tube video if you were scammed so no one else is scammed.  Alternatively you may find the secret of unlimited  energy inside and without a patent you can build a huge version and buy a tesla motor car and drive it around for free.
txt
Me too, I believe that the simplest way is disassembling it, but would understand that someone might hesitate. Common X-Ray scanner would work fine through the thin aluminium walls. X-ray is used also in better equipped car repair shops for inspections of engines, and there is a heck a lot of more metal in the way. RF would not work, of course, that's also why it is nonsense when they claim it harvests energy from Schumann resonannces.
conradelektro
Quote from: Nink on February 09, 2016, 12:26:05 PM
...........   maybe some new age tech we have never seen before etc.
It must be "some new age tech". I believe it really is what will save mankind.
....... you may find the secret of unlimited  energy inside and without a patent you can build a huge version and buy a tesla motor car and drive it around for free.
I will do exactly that. I am pissed off by Teslamotors who falsely use Tesla's name and do not have a OU car. I will not buy a car from Teslamotors. I will turn my Mercedes into a OU car. Or may be I get one of the VW cars which have to be taken back by VW (because the exhaust is less clean than claimed by VW).
I ordered ten wonder flash lights, to guarantee to have enough power for a car.
Oh my god! TheCell please tell us, is there some exhaust from the wonder flash light?
Greetings, Conrad
