World's first real Free Energy Flashlight - no shaking - no batteries! No Solar
Started by e2matrix, August 29, 2015, 09:01:12 PM
Quote from: gravityblock on August 29, 2015, 10:31:34 PM
Below is a quote as found on Adgex's website on the Adgex accumulator.  It appears they're tapping into the Schumann resonance frequencies of the earth.
Gravock
And that's what makes me think it's a scam, because _as you  know_ very low frequencies generally require very large structures for efficient transmission/reception. The wavelengths of the Schumann resonance frequencies are very long indeed.
QuoteToday Schumann resonances are recorded at many separate research stations around the world. The sensors used to measure Schumann resonances typically consist of two horizontal magnetic inductive coils for measuring the north-south and east-west components of the magnetic field, and a vertical electric dipole antenna for measuring the vertical component of the electric field. A typical passband of the instruments is 3–100 Hz. The Schumann resonance electric field amplitude (~300 microvolts per meter) is much smaller than the static fair-weather electric field (~150 V/m) in the atmosphere. Similarly, the amplitude of the Schumann resonance magnetic field (~1 picotesla) is many orders of magnitude smaller than the Earth's magnetic field (~30–50 microteslas).[21] Specialized receivers and antennas are needed to detect and record Schumann resonances. The electric component is commonly measured with a ball antenna, suggested by Ogawa et al., in 1966,[22] connected to a high-impedance amplifier. The magnetic induction coils typically consist of tens- to hundreds-of-thousands of turns of wire wound around a core of very high magnetic permeability.
https://en.wikipedia.org/wiki/Schumann_resonances
If they are really picking up significant energy from the SR in a handheld flashlight-sized object.... they are doing something very scientifically significant and important. So where are the peer-reviewed papers?
(Also note the mention of neutrinos in their literature.... red flags all around that bit.)
e2matrix
Subharmonics?   Or very fine gauge very high wind coils?    Why does the mention of Neutrino's make it suspicious?  I've been hearing about Neutrino's for a couple decades.    http://www.ps.uci.edu/~superk/neutrino.html   Do we really understand Neutrino's yet?
Jimboot
Quote from: TinselKoala on August 30, 2015, 02:33:31 PM
They are an unlisted Australian public company. Just read their investor pres from a year ago. My reading of suggests they were going to back door list by acquiring a small mining stock. This is not uncommon here, however it looks like that didn't happen. Still find it odd they would choose Australia to setup in. May have to buy one of those torches and send it to one of you brainiacs.
The other thing that is unusual is there is no 70+ Aussie white male on their board. Unlikely to get institutional investors without out imho
gravityblock
Quote from: TinselKoala on August 30, 2015, 02:20:29 PM
60 lumens per watt? Some LEDs are much more efficient than that.
If you were paying attention, then you would have noticed at the bottom of the image it says, "* the pre-defined luminous efficacy are the typical/average values", for that particular light source selected.
Gravock
Quote from: gravityblock on August 30, 2015, 07:53:27 PM
Gravock
For certain (obsolete) values of "typical/average".
If you were building a "free energy" flashlight, would you select an inefficient LED? If you were paying attention, you might have read the LED data sheet I attached to my post. Those LEDs cost about 65 cents US singly and a lot less when ordered in quantity.
