World's first real Free Energy Flashlight - no shaking - no batteries! No Solar
Started by e2matrix, August 29, 2015, 09:01:12 PM
skywatcher
 Update:
18.02.16    00:00:00    260
                                     t=30sec    t=60sec    t=90sec
18.02.16    19:00:00    1280         1090         963
19.02.16    19:00:00    1770         1460        1260
20.02.16    19:00:00    1520         1280        1115
21.02.16    19:00:00    1480         1230        1070
22.02.16    19:00:00    1060         895          795
23.02.16    19:00:00    790           685          610
The value for 'fully charged' would be > 28000.
txt
Thanks for the data Skywatcher! It does not leave any doubts. Updated graph below:
Please note that the label inside the graph should start with "24 hours ..." not "4 hours"- it was trimmed during the export into the PNG image, and I am lazy doing it again
skywatcher
Update:
24.02.16    19:20:00    485           425          389
Nink
Quote from: skywatcher on February 24, 2016, 01:23:32 PM
Update:
Sywatcher I am guessing you live in Faraday cage inside an underground bunker.
Void
Quote from: TheCell on February 23, 2016, 07:48:05 AM
And here the results of my ELFE Flashlight
Only to remember :
2weeks ago ; I drained to the possible lowest light intensity with an test one day after to check out it's capability to recover
Now it lay on the table, switched off and untouched for 2weeks and yesterday I ran the test again and it was dissapointing:
Because it doesn't seem whether you let it recover for one day or for 2 weeks, the result is pretty much the same:
The lamps brightness when switched on is medium bright and it's intensity decreases pretty fast: after 15minutes it is on a fairly low level and after a total duration of 23minutes it is on a far more low level it will probably stay on for the next 2 hours.
When I first tested the lamp it ran for 2 hours with allmost no decrease in intensity at a far more brightness compared to the switched on state after 2 weeks.
Here the pics: the first link is the intensity at start of the test after the 2 weeks.
http://overunity.com/downloads/sa/view/down/608/
http://overunity.com/downloads/sa/view/down/607/
http://overunity.com/downloads/sa/view/down/606/
The results are so clear , that I don't need exact measurement do draw the conclusion , that it did not fullfill the expactations of a 'free energy self charging flashlight'
Hi TheCell. Yes, it appears that you have confirmed that the ELFE flashlight is a scam.
Two weeks left 'charging' and it did not even come anywhere close to fully recharging.
It does not appear to have recharged the batteries at all. That looks like just the normal bounce back
effect that batteries will show after being left sitting for a while. You could now contact Adgex and ask
for a full refund and point out that you left the flashlight 'charging' for two full weeks, and the batteries
did not recharge at all. It would be interesting to hear how Adgex responds to this. :)
