World's first real Free Energy Flashlight - no shaking - no batteries! No Solar
Started by e2matrix, August 29, 2015, 09:01:12 PM
Pirate88179
Quote from: esaruoho on February 14, 2016, 05:29:03 PM
Here's a shot from the video, with ADGEX innards showing. Can anyone identify the lot of them?
(image from: https://www.youtube.com/watch?v=5HfAKX7TwiE)
Well, I can identify this major component.  It is very hard to see and, you need special glasses to be able to see it but, trust me, it is there.
Bill
txt
Quote from: esaruoho on February 14, 2016, 05:29:03 PMHere's a shot from the video, with ADGEX innards showing. Can anyone identify the lot of them?
I'd tell everybody indeed can. It contains everything I would expect a cheap flashlight should contain - the body, the reflector, the battery holder, the button switch, the LED holder, the batteries, and couple of rings to hold it all together.
The miraculous part, according to Mr. Ivchenko, is the body of the flashlight working as a resonator. If you believe him, the picowatts of Schumann resonances (low frequencies beginning at 3Hz) and nanowatts or microwatts of other EM radiation, are somehow "amplified" by the resonance of the alu tube to hundreds of miliwatts. First of all, I did not know resonators can generate energy - from a tiny, barely detectable amounts of energy, they create 10 orders of magnitude higher levels! That alone is worth of many Nobel Prizes, because it would mean we do not need any strong power plants, or thick high tension power lines. We can simply distribute just milliwats of electricity, put an ELFE resonator (a simple aluminium tube) into every house, and it will amplify those milliwatts to many kilowatts. How simple! I wonder why nobody had the idea before now.
The other Nobel Prize should be awarded for the extreme-wideband resonator that works for frequencies from at least 3Hz to 5GHz (wavelenght from thousands of km to cm). It must be the magic shape of the flashlight. I hope that they patented the shape too.
[/sarcasm]
tagor
Quote from: Pirate88179 on February 14, 2016, 05:57:43 PM
Bill
("The Emperor's New Clothes") (1934), «Krasnaya Shapochka» ("Little Red Riding Hood") (1936), «Zolushka» ("Cinderella") (1938),
https://www.buffalolib.org/vufind/Record/1731687
skywatcher
Today i picked up my ELFE at the post office.  :)
It looks very nice... but the switch might need some improvements, the first time i switched it on it only flashed for a very short time. After some gentle shaking it worked normally.
The light is quite intensive. I can even feel some heat on the skin when i put my hand some cm in front of the LED. So the 3W mentioned in the spec might be realistic.
Now i will start testing. I will make a setup with a tube where i can attach the lamp on one side and a digital luxmeter on the other side. Then i will take some readings every 10 min or so until the light intensity drops to 50% of the initial value. After some recharge time i will repeat the same procedure, until the batteries are completely empty or until it's clear that the amount of energy drawn from the batteries is significantly higher than what could be expected from normal AA size accus.
I have noticed that it's possible to unscrew the front ring of the lamp. But i have not opened it yet. First i will do my tests...
Nink
Quote from: txt on February 13, 2016, 04:47:37 PM
Excellent :D So how many "recharges" are you now at?
I have used it for 3 hours at a time dischagarging and letting it recharge 100 times in the past 24 hours. I also tested the life of 20 years in the past 24 hours.  I did this using the time travel technique built into ELFE
Quote from: markdansie on February 13, 2016, 08:00:42 PM
@ Nink
That stealth technology is amazing. I could not see anything housing it. This is really ahead of all other technology.
Kind Regards
PS I have one running in a normal flashlight, does bounce nicely
The secret patent pending solution that allows it to work without a case is the magnetic resonating flux converters strategically placed between the power discharge recharging modules.  Yes it may just look like 3 magnets sticking 3 batteries together but this is an enhancement over the original ELFE design.
