Clem Engine was the real deal, I now know how it works and can prove it!
Started by TommeyLReed, September 18, 2015, 07:46:37 PM
TommeyLReed
Hi All,
I will explain how I plan to created a hydraulic vacuum by designing a centrifugal pump that pulls cooking oil or hydraulic oil through the hydrostatic motor.
This is the basic design, using a redesign centrifugal pump with a lower cone to pull liquid fluid upward and outwards at a high volume discharge.
One important fact is as the liquid is force outward due to inertia and  centripetal force, you will have a constant rotational load no matter how much liquid is mover outward. In other words, due to the fact it rotates in open air and the fluid is move away from the centrifugal pump, you won't have to add more power to it.
Once a object is rotating like a flywheel, it takes less energy to keep it going.
As the fluid leaves the centrifugal pump, it draws more upwards to replace it. In other words if the discharge is move 100GPM outward and the intake port is much smaller, it must speed up to replace the discharge volume. This is also where vacuum pressure is created.
Tom
MIdone
Tommey,
I was reading your discussion and a word that I hadn't see for a long time came up; CEACU.
Thought I could give you a little info that isn't on the web.
1989-1992 I was getting a newsletter called; 'All Source Digest' that was the main promoter of the CEACU.  It went belly up after the CEACU fraud scam.
The CEACU (Centrifugal Energy Amplification and Conversion Unit) was the invention of Donnie C. Watts. -(died in 1992).  I don't know if he was spinning off the Clem Engine idea or not.  His idea was first mentioned in another newsletter; 'Perpetual Motion Progress, Monthly Energy Newsletter May 1, 1977.
The All Source Digest I was getting was out of Morton, WA, (editor Byron Peck) who had an agreement with Don Watts to develop and and license the CEACU.
Their best prototyper was Geoff Miller, though they mentioned they had around 30 at that time.  There were many claims of over unity, and any month would have units and kits ready for sale.  -(Waiting for the right parts, and financing.) They were selling expensive how-to video tapes, disclosures, and licenses to commercially develop.
What you are trying to do is very similar to what they were trying to do; and in fact said they did.  I played around with the idea then, with the hope that I my physics class missed something.  Even bought a video; that proved nothing.
With my experimenting; what I was convinced that was happening, was that it accumulated energy increasing in rpm's until it destroyed itself, or friction equaled the input.  It was fun; helped me learn things, but a dud.
There are floor cleaners available using spinning rim water jets, that you run with a pressure washer.  They may have parts that you could use if you keep working on this.
I just did a little search and found that Geoff Miller is still doing some with it; making the same claims to Sterling Allan as he did 24 years ago:
"https://www.youtube.com/watch?v=ilStbRJZTu0"
