PLEASE ALERT THE WORLD ABOUT THIS HIDDEN UFO TECHNOLOGY IN BIBLE
Started by that_prophet, October 11, 2015, 08:11:48 AM
that_prophet
Quote from: that_prophet on September 17, 2016, 06:33:48 AM
free energy is done using pulleys
http://free-energy.yolasite.com/
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS THE GEM OF AC ELECTRICITY MULTIPLIERS
GEM =(Geometrical Electricity Multiplier)
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
citfta
that_prophet
if you attach a 100cn circumference pulley to a DC motor
it only takes one spark of DC current to rotate DC motor one full rotation.
this would give you 100cm of moving belt to work with
now if you run this length of moving belt past 1to10 mini -pulleys.
of one centimeter circumference with AC generators attached to each pulley then.
you would get 100-1000 units or cycles of AC electricity.
these are free running AC generators=(as no load is on them)
all of these generators are running with zero load = no electricity being used
just the fluid friction of the bearings is your only wear or load-type
but you could use magnetic bearings + have practically zero friction
so all of these AC generators are just winding up massive voltage
which can be accessed as potential  = ability to do work = available current in load
you have just made your first self powered set of running AC + DC generators
that you could tap power off of + the more mini-pulleys with AC + DC electricity
(now.... don't you think that you could be able to get one spark of DC current)
( out of the 1000 units of AC electricity that you have for an output)
(this would make this unit a self powering mechanism = perpetual motion)
(+ this could be producing an unknown amount of AC + DC electricity)
I happen to be Born Again + want this super simple free energy technology out
before the first Door closes for Christ to return in the clouds by or before 2019.04
It warns us that no one knows the day nor hour... but it says that we will know
when it is near... near to what? maybe the door.... as we can know "even at the doors"
This way the Tribulation Saints have it to keep warm in our cold Canadian winters
even off the power grid. (remember fires would give away your position)
Doors are plural because He does show up twice = Rapture + at end of Tribulation
that_prophet
Quote from: webby1 on November 16, 2016, 09:13:39 AM
I take it you have still not built it,, and yet here you are still preaching false information,,
I guess that would make you that_FALSE_prophet
Sorry... but I have been having a few problenns... like nny electric wheelchair has been broke for the last 2 nnonths at least...
I have had urinary track infections... 3 at one tinne... ubheard of - or so the doctor + lab technition have said... + even worse - I fired nny doc for allowing her patient to get 3 bladder infections = spinal cord injury = T12 coplete break.
I had hoped that the Lord had given His Servant a good enough discription to nnake it seenn obvious how it works
how do you explain away the 1000 units of AC electricity output... for the one spark of DC current input
= OBVIOS GAIN IN ELECTRICAL POWER
that_prophet
Quote from: webby1 on November 17, 2016, 05:13:32 PM
Until you build it you will never know,, you have been informed how many times now about your spark,, to many to count.
(PLEASE EXPLAIN ABOUT NNY SPARK...)
You have had a few actual mathematical explanations with the real world interactions provided to you but you still fail to accept that information.
(WHAT NNATHIATICAL EXPLAINATIONS + INTTERACTIONS)
There is NO explanation needed because you DO NOT get the gain you think you will with the setup as you have described it.
(WHY DONT I GET A GAIN... FRONN INPUTING ONLY ONE SPARK OF DC CURRENT + GETTING OUT 1000 CYCLES OF AC ELECTRICITY)
Try this then,, clip as many playing cards as you can so that your electric wheelchair makes those kiddy sounds,, clicking on the spokes,, the more the better,, see how much time you loose off of a charge with just those little sparks of noise,, for your condition that would be 1000 cards,, I doubt the chair would move with 1000 little playing cards in the way,,,,
(TOTALLY CHILDISH RESPONSE = I HAVE 3 YEAR ELECTRICAL ENGINEERING TRAINING + 1 YEAR OF COPUTER GRAPHICS SPECIALIST + 2 YEARS OF INFORATION TECHNOLGY + WITH 5 POINTS NNISSING ON ONE COURSE - TO HAVE HONORS IN THE LATEST SCHOOLING THAT I HAVE HAD) = AFTER THE CLOSED HEAD INJURY
ALSO - TO GET OUT OF A NURSING HONNE AFTER A SEVERE CLOSED HEAD INJURY = WHERE I DIED TWICE + THEN WAS DECLAIRED BRAIN DEAD = THEY CUT OFF THE LIFE SUPPORT + I WAS BLESSED ENOUGH TO START BREATHING ON NNY OWN.
IN ORDER TO PROVE NNYSELF CAPABLE TO LIVE ALONE IN AN APPARTENT I LEARNED THAT I HAD TO PROVE NNYSELF  CONNPETANT-(ABOVE 85) = SO I TOOK 2 IQ TEST = SCORING 135 ON A TEST RATED ACCURATE UBTIL 120 =(+15 ) + A 165 ON A TEST RATED ACCURATE TO 145 =(+20)
HOW DO YOU EXPLAIN AWAY THE GETTING 1000 CYCLES OF AC ELECTRICITY................ ALL WITH AN INPUT OF ONE SPARK OF DC CURRENT
