Gravity magnetic lever wheel working in WM2D (could this work in reality!)
Started by inroades, October 18, 2006, 02:28:58 PM
inroades
   Thanks Stefen
  I will try to answer every question.
QuoteDid you enable the friction also in WM2D ?
Yes I did, friction is set for every part and air resistance is set to slow.
QuoteHow are the magnet forces simulated
Magnetic forces are set to 17.701 and  (field)
QuoteIs WM2D also doing this now ?
Yes it is. If I can email the file to you I will.
QuoteHow much weight do you have on the fulcrum with these
2 weights ?
The lever weighs 115lbs the weights/magnets weigh 1.5 lbs each. I have placed more weight on each side of the lever and the RPM's decrease and the torque increases but the wheel always accelerates.
QuoteAnd the green wheel, what is it exactly doing ?
Yes the wheel only positions the lever and harnesses the torque.
QuoteDid you enable also there the friction ?
Yes friction has been enabled everywhere I think.
      I will try to attach the wm2d file for your inspection, again I am new to the program and am not sure of the results, but am getting encouraged.  This will be much more easy to build the the centrifugal gravity wheel ;D
    Thanks
     Dale
      Freeenergy
      Hello
    I am willing but probably not qualified or capable of testing your wheel, Greg&Gregory helped me with my Centrifugal Gravity Wheel and did a great job,I am Questioning my on results because of my working ignorace of WM2D.  But I would be more than happy to try.
     Thanks for your insite on this project.
         Dale
There is no limit to what a man can do or where he can go if he doesn't mind who gets the credit.
hartiberlin
Okay Dale,
please try to attach the wm2d file
or a zip archive of it to a reply message over here.
Many thanks.
Best regards, Stefan.
ooandioo
Quote from: inroades on October 19, 2006, 11:33:25 PM
Wrong file sorry, here it is.
  Dale
What WM2D Version are you using? I cannot open the .dta with my WM2D 2004 V 7.0
Andi.
inroades
   Hello Andi
   I tried to open it as well and can't, It would not let me export a wm2d file,  but I can save it as and send it.  Please try the file below.
     Thanks
      Dale
ooandioo
Quote from: inroades on October 24, 2006, 10:20:12 AM
   Hello Andi
     Thanks
      Dale
Thank you.
Its really amazing - I never saw such a "working" overunity model in WM2D. This is really running...
:o
