0 Members and 36 Guests are viewing this topic.
seychelles
Just another idea to increase the efficiency of this experiment.
the electromagnet has to be polarized as per diagram .drilling the
hole is ease .place the core in a vise and tighten the vise as much
as you can then drill the hole or holes..then place the cerramic
magnet as diagram. you can use you scale to check if there is a magnetic
pull increase accordingly . Good luck. LUCKY LUKE..
gotoluc
Quote from: seychelles on December 03, 2015, 07:25:19 PM
Thanks seychelles,
I don't know if I missing the benefit of your idea but as soon as you add magnets you are now adding potential of this device to generate electricity (generator effect) no?
Please explain if I'm not understanding
Luc
verpies
Quote from: gotoluc on December 03, 2015, 07:20:46 PM
I understand but I didn't know for sure that an Inductance boost during on time will make the flyback have more power. This is what Steorn Orbo was claiming but I never saw any proof to it. Is this what you're sawing?
Yes, but you can leave that improvement for the last supper.
verpies
Quote from: gotoluc on December 03, 2015, 07:24:42 PM
I'll test "The elegant method" next time this issue comes up.
If you can get four of these HEF4047B cheap chips (CD4047) then I could draw you a schematic that will allow you to trigger on the edge of that white tape and have an adjustable ON pulse width (independent of the tape width) as well as a signal for emptying that capacitor later.
All I would need to know is whether that pulse from your opto is positive going or negative going....
gotoluc
Quote from: verpies on December 03, 2015, 08:13:10 PM
Okay, then how about you share on the results you saw in my last video demo before it broke apart. Do you think this design idea has any value?... what changes would you make if it needs any?  etc.
Thanks
Luc
