Inductive Kickback
Started by citfta, November 20, 2015, 07:13:17 AM
AlienGrey
Perhaps trouble makers on this site should have 'Names' in colors so as to warn others to be aware of misleading information or deception after a warning by admin!' no one with intelligence can be that much of a minion, surely !
Just a thought !  the pages are getting filled with totally misleading ''rabbit hole fodder probably deliberately'','' probably laughing him self stupid on the wind up'', no one can be that stupid, can they?
AG.
citfta
Quote from: synchro1 on February 26, 2018, 06:35:13 AM
@Citfta,
Look, it takes a diode to loop the inductive kickback. The flyback is higher in voltage, so it wants to go home through the positive electrode of the battery from whence it came. The flyback Will travel in the same direction if you send it down the ground drain, I'll grant you that, but you just have it wired wrong.
You have posted another one of your mistaken ideas.  The flyback voltage will only go as high as it needs to go in order to return back to the coil.  If there is a high resistance in the path then yes the flyback voltage can be higher than the applied voltage.  But it is only higher in relation to the other end of the coil.  Not some imaginary connection on the other side of the supply.  If the return path is low resistance then the flyback voltage will be lower than the supply voltage.
It is amazing to me that you have wasted at least two years of you life trying to convince the rest of the world that you are the only one that understands how a coil works.
synchro1
Quote from: citfta on February 26, 2018, 06:48:16 AM
@Citfta,
You're the one that needs an elementary text book pal. The flyback wants to return home without the diode, thats why we need tiny capacitors on our switches.
citfta
Hi AG,
Yes it is unfortunate that anyone can post anything they want on most forums, even when their ideas are clearly wrong.  On a couple of other forums I have a signature that says" Just because it is on Youtube does not make it real".  And of course the same  thing applies to most forums.  There are no forum police to check all the things posted so anyone can post anything and get by with it unless someone else decides to challenge them on it.  The threads that are clearly foolishness I tend to just ignore.  But sometimes I feel the claims are so misleading they need to be corrected.  I have seen several times on these forums where people have spent a lot of time and money chasing some idea that was false from the start.  I feel like if I know for certain an idea is false I should at least explain why I think so in hopes of saving someone many hours of time and a lot of money.
I hope my explanations about inductive kickback have been helpful to you.
Respectfully,
Carroll
synchro1
Quote from: citfta on February 26, 2018, 07:01:35 AM
Hi AG,
Respectfully,
Carroll
@Citfta,
I don't have to respect you and that other crackpot for acting like important authorities because you show one isolated effect in your tedious videos with your inane scope shots. I don't have to upload any videos of getting bit by flyback. That's why we call it flyback.
