Inductive Kickback
Started by citfta, November 20, 2015, 07:13:17 AM
forest
Let me rephrase my question , still not answered and nobody interested in : the collapsing field of disconnected coil is the source of EMF or EMF and current ? For example if the coil is part of boost converter does it only provide additional emf which is added to emf from battery or also produce the current ? Or maybe it depends on coil type or other factor ? Because boost converters are not OU I suppose coil is not producing current, but that's jsut my blind guess....
synchro1
Quote from: forest on February 28, 2018, 01:38:11 PM
@forest,
When the current is interrupted from the source, the magnetic field in the inductor begins to collapse from the outside in. This collapse generates power, both current and voltage, that together are both an entirely new event.
AlienGrey
Quote from: synchro1 on March 01, 2018, 05:26:46 PM
@forest,
Mr Syncro have a look at his series off lectures MIT 8,02 try and re program your self, good luck https://www.youtube.com/channel/UCiEHVhv0SBMpP75JbzJShqw  lecture 1
sm0ky2
synchro1
Quote from: AlienGrey on March 01, 2018, 06:20:01 PM
@AlienGray,
Maybe I should read the entire "Encyclopedia Britannica" from A to Z while I'm at at too for you? How would you like it if I gave you seven Herculean chores for homework? Can you make a specific point please?
