Inductive Kickback
Started by citfta, November 20, 2015, 07:13:17 AM
synchro1
@Magluvin,
Congratulations on the definitive and complete obliteration of the false Milehigh position that there's no difference between the bifilar and single wire coil. Excellent video. I urged Tinselkoala repeatedly to test the two coils with pulse power for years, and the only tests he ever performed were tests with constant current, both D.C. and A.C. to arrive at the erroneous conclusion that Tesla was just a dummy.
tinman
Quote from: synchro1 on March 04, 2018, 12:56:02 PM
Current reading of inductive kickback on the "Reed Switch Spinner": The kickback voltage measures 6 volts. Naturally the input is 12. The BEMF output measures around 50 milli watts:
https://www.youtube.com/watch?v=eT2VcWNIKA0
Well syncro,your video just proved i was right,and you are wrong.Inductive kickback is a direct current (DC),and what i said was that the generating effect of the spinning magnet is what was sending current back to the source,as the spinning magnet would produce a alternating current(AC) across the coil.
You just showed a video,where you were measuring alternating current,and trying to pass it of as the inductive kickback current, lol--whats the chances of that.
Enjoy.
synchro1
Quote from: tinman on March 05, 2018, 01:53:56 AM
Enjoy.
@Tinman,
The inductive kickback measures around the same on the D.C. scale. I just measured the input current, and I'm processing a video of that right now. I'll upload it soon. The input current is around 200 mA  D.C. at 12 volts. This gives us an input power of around 2.4 watts and an inductive backspike of 50 milli watts. That's right around a 20% recovery figure. I 've measured this COP in the past with my Bedini circuits and the ratio is the same, so I certain my figures are correct.
The good news is that the Inductive kickback directed to the ferrite core series bifilar coil through my 70uF 25 volt capacitor with no diode (The diode kills the effect) is generating a very powerful oscillation in the overhead ferrite magnet elastic band piston. The problem is, that it's at the same frequency as the R.P.M. of the spinner which measures around 3300 R.P.M. with my frequency meter. This oscillation frequency is too great for my commutator to keep up with; However, this amounts to real progress in my opinion. We have Magluvin to thank for this ingenious path of discovery.
tinman
Quote from: synchro1 on March 05, 2018, 06:48:54 AM
@Tinman,
QuoteThe inductive kickback measures around the same on the D.C. scale.
So,your meter reads the same amount of current on both the DC and AC setting--thats great :D
Fantastic
You should both be up for your nobel prize any time soon.
