where does energy come from
Started by markdansie, November 20, 2015, 10:34:44 PM
seychelles
TECHNOLOGY OR SO CALL FREE ENERGY IS NOT GOING TO BE OUR SALVATION
BUT OUR MASSIVE IMPROVEMENT IN OUR MORALITY IS GOING TO
BE OUR SALVATION. AND I AM SO VERY SORRY BUT I CAN SEE THAT
HAPPENING VERY SOON. I will give you all a riddle that most of
humanity have failed on WHAT IS SO EASY TO DO AND YET SO HARD TO
PRACTICE OR DO.. IT IS THE ELEVENTH COMMANDMENT. LOVE YOUR
EVERY LIVING ENTITIES AS YOU LOVE YOURSELF AND LOVE YOUR GOD
WITH ALL YOUR MIGHT.
forest
MoRo
Quote from: profitis on November 23, 2015, 04:52:28 AM
Quote moro:"Sometimes, we don't necessarily need to know how something works. We only need to have appreciation  that things are designed in such a way that we benefit from the way it all works together."
True but this does not mean that we should not dig deeper as we've been doing all through history.we've come to a point where we have to examine our questions rather than answers and I think that a lot of our questions are thwarting further knowledge and need immediate ammendment
Yes. It's why I have the understanding I do now.
Quote from: tinman on November 23, 2015, 08:24:51 AM
I think you will find that it is the gravitational pull on the earth from the moon that causes friction that causes the heat within the core. The earth plates are being pulled and distorted by the gravitational pull from the moon,and this creates large amounts of friction,which creates large amounts of heat. Part of this may be caused by the tide's-i am not sure on that one.
True, an earth sized ball of atoms is not massive enough to become self sustaining at heat production, like a star is. So most of the internal heat in the earth definitely comes from friction due to the Earth/Moon tug of war. Also, Tides are gradually slowing the spin of the earth and moving the moon to a higher orbit (about an inch a year).
Quote from: seychelles on November 23, 2015, 10:40:48 AM
BY the way helium is the second element on the elementary table .
under great gravitation and earth mantle pressure the hydrogen
in deuterium which is h3o is upgraded to helium3 and a massive amount
of heat energy is generated.
The first element on the Periodic Table is Hydrogen. But nobody seems to mention that it too is likely in production in the stars. After all, ALL matter and energy are exchangeable, as atoms are made from sub particles. Why else would it still be so abundant. Likely, anti Hydrogen is produced too. (though it would have a very short life within a non-antimatter star, and produce lot of heat).
Quote from: Newton II on November 23, 2015, 04:42:00 AM
I have got a question here.
Human body is flexible.  So,  when you push a car, your body should fall back in the absense of a internal supporting force.  But practically this doesnot happen. So,  what provides internal support to the body preventing it from falling back?
Does it mean that human body is unscientific which doesnot obey Newton's third law?  Do we apply force by hand or through mind? Psyche?  or spirit??
The atoms throughout your body are held in place by charge forces. These charge forces generate heat when flexed (friction). Take a paper clip bend it back and forth in one spot. Then feel that spot. Ask yourself: Why did it get hot?
MagnaMoRo
Newton II
Quote from: MoRo on November 23, 2015, 06:17:18 PM
All machines have atoms but what provides the support?  Can you drill a hole in the wall using a drilling machine without supporting the drilling machine despite consuming electricity from the mains?
What provides support to the human body while doing work when you consider the entire body as one unit of a biological machine?
MoRo
Quote from: Newton II on November 23, 2015, 07:37:00 PM
I am not real sure if I understand what you are asking. But, consider a piece of steel (the paper clip for example). Even though to us it seams to be 'solid', the space between those atoms is enormous compared to the size of the atoms themselves. Those atoms though are all 'locked' in a certain arrangement by charge forces .  You as a human also have atoms 'locked' in a certain arrangement by charge forces. Pound for pound bone is stronger than steel. Your bones support your flesh. Your flesh more weakly supports whatever your holding. You can overcome these forces and break steel, bone or flesh, just like you can pull magnets apart. Everything around you is held together and separated by comparatively week or comparatively strong charge forces.
Charge forces generate heat when undergoing acceleration or declaration. Extreme gravity, as in the case of a star will cause an extreme acceleration condition for atom held in place by the atoms 'below' them.  So, heat is generated.
