where does energy come from
Started by markdansie, November 20, 2015, 10:34:44 PM
SoManyWires
Quote from: profitis on November 27, 2015, 03:16:45 AM
Quote somanywires:"having yet to reach warp speed yet, and during the
volume ramp curve would be forms energy
depletion, if light intensity or magnetic fields gravity
could remain a constant or develop greater radiation
according to the direction of velocity if that was
travelling towards the sun for example,  could speed
not be increased? is solar wind a resistance?"
Wowi!,matter and change are interconvertible? Or matter is just changing faster and slower
if a solar cell can grid and become a solar panel, it can gather more energy from the light source faster than if it was still a solar cell.
a light source, or focused light such as a laser could be aimed at a cell or diffused like the sun for use on a freznel lens with a panel could help matter work against gravity from this using it as a power source for a drive system.
look, after building well over 42 space ships that do work for several international customers and have been in operation for 1000's of years, i can verify the energy transfter to be true.
in fact i'm typing this from an altitude of 140 miles and climbing.
ok maybe not, yet.
dreaming in the clouds like the fool on the hill, thats ok, the views go on for miles and miles and miles and miles and miles and miles and miles..oh yeah.
Tito L. Oracion
Quote from: profitis on November 26, 2015, 07:47:27 AM
"Energy simply comes from   movement. 8) "
And movement from energy.catch 22 there's only one question left to ask and that is :what is energy/matter.what not where
@trytis
Are you not reading the question?, it is "where"
Now you say "What" then that's another question, understood?
And regarding your question "what is energy" then energy is the cause of the movement happen. :o
And matter is anything that occupy space and has weight, And that's!!! elementary!!! >:(
matter is not energy!!!! when matter is moving it performs an energy and the size of that energy is depending on the size, weight of the matter! plus the the speed of the movement!. What's the matter with you! ;D
Changes are just the results or effects of movement.
meaning energy was happened already before changes has seen. did you get it class? ;D
Time?, i don't know why time is included. Why?, are we going to use the stopwatch as it moves. i don't get it. ;D
Therefore when moving it performs an action of energy!, got it.?
now, did i made a little help for clarification!?, you boaster!!! >:(
everything is helping here!!!! even wrong answer, understand? >:(
otytis ;D
Tito L. Oracion
:) ;) :D ;D >:( :( :o 8) ??? ::) :P :-[ :-X :-\ :-* :'(
Let someone look at your eye.
Look at them one by one, in time you are looking at them, you are exerting an energy at their gap.
because you need to see the other one.
its an stress reliever actually and good for those who has an atrietis.  :D
and it does help.  ;D
profitis
Ya ok guys so change affects change.if change causes change to change then whats the right question to ask here. should've rather asked,"what is changing" as opposed to "where does change come" from right?
profitis
Make up your minds guys what do you wanna know a) what is change or b) where does it come from.if you ask  b) you go in cycles.if you ask a) you go in a direction?
