Thanks to ALL for your help!!
Produce heavy water
Started by franco malgarini, December 11, 2015, 05:13:07 AM
franco malgarini
This is a cycle of production of heavy water, and therefore of deuterium, automated electronically,
electrolysis with successive electrodes amalgam that also produce atomic hydrogen
that is done recombine in successive stages obtaining heat and electrical energy.
For which the system is self-perpetuating in time:
The amalgam electrodes are electrodes for electrolysis of water made of an alloy of mercury with a metal, which can be sodium, lead, platinum, that have the characteristic of producing atomic hydrogen and not molecular hydrogen during electrolysis.
The atomic hydrogen recombines immediately hydrogen molecular providing temperatures of 4000 ° C usable for furnaces to multifunction multiple successive stages in which one can obtain the synthesis of chemical elements at high temperatures, and the outputs of which molecular hydrogen is obtained for other cycles:
________________________________
http://nuovachimica.forumcommunity.net/
franco malgarini
sm0ky2
I have discovered a better way to create Heavy Water
Simple, safe, and effective.
Take a unit of pure lithium metal in a tempered glass beaker
(Lithium Oxide from batteries can also be used)
and slowly add water, and wait for the lithium to react
continue this process, until all of the lithium has dissolved
some of the hydrogen and oxygen is released from the water, and you are left with a
highly concentrated Lithium Hydroxide
Dilute this to 10% with distilled water.
Next take Americum from recycled smoke detectors
this can be found inside the emitter
And place it into the diluted LiOH
and maintain the solution at 209.1 degrees F
Upon heating the LiOH releases its' OH ion, and picks up 4 H2O's
To become Li(H2O)4)
Alpha particles from the Americum will hit the large lithium salt
and destroy an oxygen atom.
a low energy neutron will be dissipated into the water
and a high energy neutron will fuse with the released Hydrogen ion
The lithium (Li(H2O)3) will then react with another water molecule
D will combine spontaneously with free atoms in solution.
Forming DHO, and D2O
H2O will condense in the vapor and a flammable mixture of OH- (hot gas)
will be in circulation.
Water vapor from the condenser can be siphoned back in and the gas bubbled
back up through the reactor.
once water vapor stops making it up the tube and into the condenser
remove your heavy water for purification.
To purify: (first stage)
Filter the solution and salvage the Americum catalyst
Next simply distill the water in solution and the lithium will calcify in the beaker
for simplicity some liquid is left to facilitate repetitive cycles.
This process can be continued to create reactor grade concentrations of DHO/D2O
This should be done outside or with a suitable vent hood to evacuate any remaining gasses.
seychelles
WTF SMOKEY IT IS EASIER FOR ME TO INVOKE THE DEVIL THAN TO DO THAT SHIT.
seychelles
DON'T YOU HAVE ANYTHING BETTER TO DO SMOKEY.
