new here! several questions
Started by sumhungl0, December 23, 2015, 01:59:17 AM
the_big_m_in_ok
Quote from: sm0ky2 on February 16, 2016, 05:58:18 AM
@the_Big
I believe what he is referring to is not a motor belted to a generator.
but rather, both in the same device.
what it sounds like to me is a standard military issue power amplification dynamo
This is a motor on the outside, but there is not a load placed on the shaft.
rather, inside the diameter of the rotor, is another set of coils that acts as a generator.
This is used to power many of the systems on board warships of the Navy and Airforce.
I didn't forget this post.   What I perceived from your post above was:
The magnets, with the North poles facing outward---and weighing a lot less than the copper coils---are spun on a shaft using only the way, way lighter magnets on the INSIDE of the rotor to be reacted against the stationary 'stator' of the coils that requires a lot less power to input and then get a full power rating from the coils.
       The thing might be...?
The magnets MAY resist the coils---hysterisis?---and this might complicate the generation of power by the fact that it happens?   The resistance may show up as a leading, pushing effect as magnets approach individual coils?
--Lee
sumhungl0
eh, i think you are not getting what i was trying to type out, bigM.
"what it sounds like to me is a standard military issue power amplification dynamo"
correct, this is what i used to work on.
so what i want to learn from this post is to start back at the basics.  i want to start with a low power consuming pulse motor.  when i get that figured out(with your help), i wanna build the generator portion(same shaft), and lastly...... do what the name of this forum means.....  more power then input.
i have seen so many videos on youtube.  this is nothing new, and has been accomplished before.
why isnt there a motor-generator that can run a house off the grid?  its there, but i cannot spend several grand to purchase a unit from quantamagnetics.com.  nor would i personally want to.  i know hes gotta make his money but im not wealthy and i would rather make my own unit.
heres where im at:
so far i have a cd with 4 neos from a few old harddrives.  that is my rotor.
i mounted it to a burned up cd rom motor because the cd holder was still intact.
thats about it at the moment.
i have reed switches(mentioned above) and they keep sticking closed because of the current running through them in series with the coil.  yes, really simple circuit is what i started with.  i am now trying to scavenge some transistors to use for the reed switching portion to limit the current on the reeds.
i have wound a few coils that are very very small, just for testing.  this might be another problem im having.  i still need to purchase a few spools of magnet wire.  i was just using a few short strands that i had around.  i will be buying at least 2 different gauges of magnet wire spools but "damn" they aint cheap.  any advice on this would be great?  site to purchase?  recommended gauges?
the design i will try to pursue is similar to quantamagnets.  probably 6 magnets on the rotor.
im not even close to that point yet tho.
i have to overcome the reed/current problem, or figure out another way, timing/commutator maybe.  would like to stay away from a commutator set up tho.
i still need to figure out the best coil type to use, how many windings of what gauge, bi-filar or not.  duno how i feel about bi-filar yet, duno enough about em yet.
i havent had much success with the cd project yet to move on to the main project.  i have not had a successful run of this motor yet.  pretty sure it is because i half-@s$ the coils.  two test coils, about 3ft of magnet wire, one wound around my pointer finger and the other around a screw driver.  i can feel the magnetism from each but i never get any rotation from the rotor.  im just holding them in place also.
so that is where im at, and where i want to go.....
i wanna stop paying power bills.
and thanks again for everyones input.
sumhungl0
here is what im planning to buy.
magnets
http://www.magnet4less.com/product_info.php?products_id=1158
maybe some different variations.  comments?  advice?  cheaper site?
magnet wire
http://www.magnet4less.com/index.php?cPath=9_20
not sure on the gauges yet.  advice?  gonna need to wind the pulse motor and generator coils.  what gauge do you want for pulse motor/generator?  im sure the pulse motor needs to be more windings of smaller gauge and generator less windings of thicker gauge.  correct?
garry s
Hi You really need to understand basics before you can understand what you are looking for and more so what you find along the way.
http://micro.magnet.fsu.edu/electromag/java/lenzlaw/index.html
This is a good place to start.
Understanding how the coil and magnets interact is the key to these experiments.
Garry
sumhungl0
Quote from: garry s on February 21, 2016, 07:13:34 PM
Garry
perfect, i will get to reading...   thank you sir.
