All Permanent-Magnet Complete Levitation
Started by guest1289, December 26, 2015, 03:35:54 PM
guest1289
I think that the  'Magnetic-Sled'  on the post below could possibly be done without any magnets,  instead,  you could just use  electrostatic-levitation
http://overunity.com/16295/all-permanent-magnet-complete-levitation/msg469597/#msg469597
You could probably also do several of the other designs in the post above,  just by using  electrostatic-levitation .
    But, I'm wondering if my magnetic-levitation designs which try to mimic the  meissner-effect,  in the post below,  could also be done just by using  electrostatic-levitation
   http://overunity.com/16298/my-levitators-and-bearings-and-other-designsinventions/msg469748/#msg469748
   I'm not sure if they can or cannot,  because of the problem of one charged-object discharging to another charged-object, since these designs are more complicated.
   So,  if anyone achieves the effect of the  Inverter-Magnet/Tractor-Beam-Magnet without magnets, just by using  electrostatic-charges, that would be impressive.
sm0ky2
that townsend-brown guy did this 50 yrs or so ago, after he started making things electrostatically levitate.
the force can be arranged to repel, propel, attract, or detract motion between the source and the opposing charge,
whether it be on the object being moved or not.
in this manner, it is much like magnetism..
what we haven't figured out yet, is how to make two repelling magnets provide a linear force, while attached to the same object.
guest1289
Quotethat townsend-brown guy did this 50 yrs or so ago, after he started making things electrostatically levitate.
I think your'e saying 'townsend-brown'  created something having the same effect as the  'inverter-magnet'  design,   in the diagram below,   just by using electrostatics,    if so,  that would mean that probably all of my magnetic-levitation designs,  could have their magnets replaced with  electrostatically-charged components ,  the problem would be charging each component with just the right amount of static-electricity.
Quotewhat we haven't figured out yet, is how to make two repelling magnets provide a linear force, while attached to the same object.
  So I think you're saying that no  magnet-motor( radial or linear )  has ever functioned successfully,  that would be correct,  and I certainly have not ever seen one.
  However,  you typed  "while attached to the same object",  I wonder if that includes  railguns,  v-gates,  and  my various versions  of my  magnet-motor-3 motors which I think would levitate-glide above the stator magnets,  on the page below :
    http://overunity.com/15774/permanent-magnet-motor/msg474394/#msg474394
    Below, is another design for all-permanent-magnet-complete-levitation  that I made, I've designed it with 4 magnets, but I don't know why it wouldn't work with just 2.
      Note   the very different direction in which the  2-connected-floating-magnets are magnetized ( their polarity ),  needed for the levitation.
guest1289
   I had forgotten to actually post the methods by which  "All-Permanent-Magnet-Complete Levitation"  could be achieved,   successfully,   by only using the most commonly available shapes and sizes of magnets.
    The methods shown in the diagram below,  should make it possible to easily build the various designs in my first post on this thread ,   and,   perhaps also my designs on the post-link  below :
