How to get a car to run on Electromagnetic Vacuum
Started by GregorArturo, January 11, 2016, 06:57:29 PM
GregorArturo
http://gregor.ninja/how-to-run-a-car-without-fuel/
"The Joe Cell was developed by a man named Joe in the 1990's from Australia. The cell is by far one of the simplest devices to utilize a low electromagnetic pressure (spacetime vacuum) to run an internal combustion engine. It has also been considered to be one of the most elusive of inventions with over-unity technologies in the free energy movement, due to both the story of Joe and the unique simplicity to its design and application. It consists of concentric layers of tubular 316L stainless steel and restructured water. 316L is not only anti-corrosive, but it is the most readily available material on the market that has a very high magnetic susceptibility and is also thus paramagnetic. It can be slightly ferromagnetic like iron initially, but once annealed and quenched, it becomes very paramagnetic. This allows the metal to amplify the earth's external magnetic field in a receptive interaction. Paramagnetism is akin to a magnetic convex lens that self-aligns to the external magnetic field (while ferromagnetism is fixed in its alignment thus being internally driven), while diamagnetism is akin to a magnetic concave lens that self-aligns. Water is slightly diamagnetic, but once restructured (such as with alternating vorticular motions found naturally in streams with vortex streets), the property is much more profound. As long as the cell is mostly perpendicular to the earth's magnetic field, when mounted vertically in an automobile, the 316L will always magnify the magnetic field inwards toward the core of the cell. However, when the magnetic field hits the water, it diverges the field. This causes the magnetic field to go into oscillation as it expands and contracts, the convergence and divergence are amplified in effect with each consecutive layer. The diagmagnetism in the core of the cell is most profound after this non-linear magnetic amplification process, which causes the magnetic field to curve almost entirely around the core. A magnetic field is a standing waveform of torsion forces and consists of stored electromagnetic pressure. A high magnetic field attributes to work in the system in the form of centrifugal force. A low magnetic field, or magnetic vacuum, attributes to potential energy in the system in the form of centripetal force."
I also have an open source crowdfundraiser on Tilt for a Joe Cell, professionally machined.
https://www.tilt.com/tilts/building-a-joe-cell-experimental-prototype
