Space Engine...
Started by iacob alex, January 10, 2016, 05:05:31 PM
iacob alex
.....-Power of Gravity , at : https://m.youtube.com/watch?v=W1TvnnWhGzk
      As usually , we must go back to nature for information...regarding the topic of our forum
      Al_ex
lumen
Quote from: Atommix93rdAtom1 on January 11, 2016, 10:27:40 PM
So where is the space engine ? Have you built it yet ? hahahahah ! do you have a lab ?
It's still in the design stage but most of the bugs have been worked out.
telecom
Can you please provide more details?
lumen
Quote from: telecom on January 12, 2016, 04:47:01 AM
Hi telecom,
This is only a single component in the overall design and it would be difficult to write text that might provide a clear understanding of how it operates.
At this point it's down to a final test that will determine if the device provides space propulsion or simply generates energy. Prior testing indicates the results must be one or the other.
If a similar device was built large enough, it could extract energy from the rotation of the Earth though it's not required to do so to simply provide energy.
I don't want to get ahead of myself until the final proof is in but I will say that after this was put on paper it does look a bit scary!
If everything works out then I will post the full design which should provide a clear understanding of it's operation.
lumen
Quote from: Atommix93rdAtom1 on January 12, 2016, 11:31:54 AM
There some problems there ! To many parts hahahah nice drawing ! Why the gearing ??? I think all you need is the ring and a unity electron field pump to give directional force ...... Always be open to optimum performance and don't get stuck with the mind games of it must work as I want it to or you risk getting stuck with something that is way down on optimum performance ...
You now need to explain its principle ???????/ how does it work hahahahahah
How can you make suggestions and modifications and then say I need to explain how it works?
