To be deleted
Started by nul-points, February 02, 2016, 07:23:16 AM
Void
Hi Itsu. OK, I see. Maybe using an appropriate CSR and using a voltage probe would
give more stable current readings.
Void
Quote from: Hoppy on December 08, 2018, 12:02:31 PM
Pot, caps and Inductor power dissipation.
Hi Hoppy. Well, in my estimation those would not account for the approx. 5 mW discrepency
as their power consumption would be fairly low, but Itsu has pointed out that his current probe
may not be giving consistent readings (at those low current values). All the best.
itsu
Quote from: Void on December 08, 2018, 01:21:00 PM
I did use a 10 Ohm 1% inductionfree csr (1 Ohm is to noisy) in the beginning and compared the values with the current probe
and found them to be very similar, but they might influence the working of the whole circuit.
So therefor i opted for the current probe as it is much more convenient to use on a fixed PCB circuit.
I think i will be very close to accurate measurements when averaging like 10 measurements or so.
itsu
Void
itsu
Collected measurement data up till now:
Itsu
