LENR and phluorescent tubes
Started by franco malgarini, February 02, 2016, 08:37:36 AM
conradelektro
Quote from: franco malgarini on February 02, 2016, 01:14:49 PM
We make accelerating the lenr reaction (electron+proton=neutron).
The problem is the power of tube: HT, 220 volts,ballast or other....
You could light the fluorescent tube with a "negative tros" circuit. It is a Joule Thief btype circuit which oscillates at about 500 KHz (if you wind a coil as specified on a 50 mm PVC tube).
I do not know if 500 KHz at about 1000 V are better than 50 Hz at 220 V, but I see people experimenting with "lightning bursts" in gas filled tubes with fancy electrodes. But that looks more like electric arc welding. Well, 500 KHz gives a lot more lightning bolts in the fluorescent tube than 50 Hz or DC.
Do not blame me, if it does not increase LENRs in your fluorescent tube, but the tube will light up nicely.
Question: The coil around the water pipe (in your drawing), how are you driving this one? High frequency, high current or DC?
Greetings, Conrad
franco malgarini
pomodoro
This system is very unlikely to ever work. Lets not even worry about generating  nuclear reactions in the fluoro tube  as yet.
Even an introduced radioactive substance in the tube will produce nothing from the coil.  Why is that? Well , because the charged particles from the radiation will all need to be traveling in the same direction with their own momentum. They must not  be influenced by any electric field to do so for a net gain.  In reality they will be flying in all directions, not just in direction of the ions, cancelling any hope of current.
Ponder for a while on the fact  that even if you throw the highly radioactive  Po 210 in the tube with gas (in the hope of generating a massive amount of  secondary avalanche electrons), all you are doing is making the tube more conductive.
Lets shield one side of the Po210 with lead, then all alpha particles will fly out in one direction! As an exercise work out the coulombs  obtainable from a few grams of Po 210 with all of its alpha particles all traveling in the same direction.  You will be very surprized at how very little current this is, although its from a very active source...
