Is the free energy gamechanger here ? 2000 Watts u-plug generator
Started by hartiberlin, February 04, 2016, 11:21:58 PM
guest1289
Quotesomething similar to a continuous loop of falling dominoes.  Because of the gears, they are constantly reset.  Instead of falling linearly, they fall radially
Thats 1 of the 2, most original ideas I have heard lately.
  everyone agrees combining gravity, and magnetic interactions,  is a step closer to trying to break symmetry,  the conservation of energy,  you could just draw one section containing a falling-component connected to a section of gear,  peoples imagination can fill in the rest
(  The other recent idea I read,  was another member,  who is going to build a space-drive powered by gyroscopes( momentum effects etc ),   and just use it as a generator   )
If you like puzzles,  my two magnet-motors on this post
http://overunity.com/15774/permanent-magnet-motor/msg470966/#msg470966
magnet-motor-1,  all the magnets on the wheel want to get to the strongest part of the stator-magnet,  the last magnet on the wheel to detach away from the stator,  could be attarcted to the beginning of the stator-loop,  and also pushed on by all the other liitle magnets on the wheel
magnet-motor-2,  if you understand it,  you'll see it also has some very original,  potential
Nink
Quote from: tinman on February 05, 2016, 08:13:45 PM
Where you getting your prices from Dog-One ?
http://www.ebay.com.au/itm/Pure-Sine-Wave-Inverter-2000-Watt-12VDC-to-230-VAC-CAR-Mobile-Power-Supply-NEW-/281861958295?hash=item41a0482a97:g:etsAAOSwZVhWTo0Q
I see a lot of (hard to get out of) claims being made on there web site.
Run with this one Chet,--see where it go's.
Maybe some one else has figured out that the magnetic force !is! a flow of virtual charged particles(which are created by actual charged particles),and have found a way to put them to work.
Brad
I do recall in the FAQ they said they don't use an inverter.  http://www.u-plugproducts.com/web/faq.php
How do we know there are no batteries in the machine?
First, no battery, by itself, puts out alternating (AC) current, the type of electricity everyone finds coming out of their wall sockets. Batteries generate direct (DC) current. Batteries come in volts listed as 12 volts, 24 volts, etc., direct current. A computer cannot be plugged into a DC current outlet. Cigarette lighters in cars are a DC outlet.
Second, assuming for the sake of argument that batteries could be put into a six inch diameter, 24 inch tall cylinder, the batteries would lose power within minutes running through an inverter to convert DC to AC power. In fact, after only a few minutes it would become so apparent that the batteries were losing power as the device hooked to the machine would begin to run more slowly, or the lights would begin to dim through the natural diminution of the power of the batteries.
Not arguing here, but I just want to clarify one point.
Many switchmode power supplies intended for 110-240 VAC will indeed work just fine on DC instead, even at a lower voltage.
Ok... carry on.
Pirate88179
This will never work as claimed.  I know why and so do they.  Funny they don't mention that in their sales info.
Sorry, I just had to say it.  So far, TK has been correct every time he has said it so...I am going with the odds on this one, along with some common sense observations.
tinman
Quote from: Pirate88179 on February 05, 2016, 10:57:58 PM
QuoteThis will never work as claimed.  I know why and so do they.
well-do tell Bill. Why wont this work as claimed?.
QuoteSorry, I just had to say it.  So far, TK has been correct every time he has said it so...I am going with the odds on this one, along with some common sense observations.
So far,everyone that has claimed that these sort of devices will never work have been correct.
So far,i have not won the big one in lotto either-but some one always dose ;)
Do you truly believe that no more progress has been made since the birth of power generation,and it's working principles ?. Have we gone as far as we can go?.
I think not. Yes-there have been many scam's over the years,but it is only a matter of time before some one hit's the Jackpot. so,do you know that it dose not work as described by just looking at it,just following TK's lead,or you know how the internals are set  out,and what they are?.
Brad
