Free Energy Party Green Machine - 3rd Party verified Overunity Electrolyzer
Started by hartiberlin, February 07, 2016, 09:40:59 PM
allcanadian
@somanywires
Quoteyou might notice that video link is for a rap video.
At least you weren't Rickrolled, that drives me loco.
AC
zorrotechnology
By the way, honorable sirs,  the Independent Test Lab hot shots were sure this would fail the testing, and were so shocked at the repetitive data results would not show them any area of failure. After retesting and instrument callibration down to .oooo1 both before and after nothing showed out of calibration. They used half a million dollars worth of test equipment. It took three months for multiple experts to review and assess the data. Then they released results.  Then the patent Office intervened asking certain secretive information on how it works not be disclosed in the patent but be removed so it would not be picked up by China, because it is a world breakthrough tech. They attempted to make them work for a DOE contractor and thereby give up control because there was approximately 22-38  uses in chemicals, pharmaceuticals , clean coal, cooling turbine bearings, etc. for immediate device applications with no mention of energy applications in large.   The Inventor didn't want to give the tech to only be suppressed and controlled and is now offering it to the world and to the people by way of  the Free Energy Party who is standing in to protect the people involved against illegal Monopolistic Restraint of Trade. We are running the Green Machine for President , we hope you vote for the REVERSING THE GRID AND MAKING THE PEOPLE THE POWER PRODUCERS in a decentralized grid instead of War over Oil as your current power producer.
pomodoro
Nink
Quote from: hartiberlin on February 07, 2016, 09:40:59 PM
Hi All,
this has been verified by an independant 3rd Party Test lab.
This Electrolyzer is generating 20 Liters per Minute HHO gas at just 500 Watts of input,
so it is way overunity.
Enjoy ! The future is Green !
This is the Green Machine from the FreeEnergyParty.org
Regards, Stefan.
OMG REDACTED tested REDACTED at REDACTED in a Carport in the rain.   THIS MUST BE REAL.  It would not be possible for me to just type that up and print it on a sheet of a4 paper without any letter heads or anyway to verify it.  THIS MUST BE REAL.  Where do I send my check.
tinman
Quote from: zorrotechnology on February 08, 2016, 11:14:19 PM
THE GREEN MACHINE
Anything under 2.4 watt hours per liter is over-united according to David Wenbert using traditional water electrolysis and applying Faraday conversion ratios ..... 500 watts for 1 minute makes 20 liters. Per liter, that's 25 watt minutes. Next divide by 60 minutes in a hour, get 0.416 watt hours per liter. If you did the math, ie 2.4 divided by 0.416, there is room to prove overunity with overground demonstrations even with a Chinese gen set running on the order of 0.25% efficiency. But for home installations we will use the 90% efficient PEM fuel cells to power the home. If I have used any incorrect terms try to help rather than attack since the Independent lab says this is a world breakthrough lets work together without animosity.
Quotelets work together without animosity.
Sounds good. Post a schematic of the circuit,and i'll get straight onto it. Will have it built withing 2 day's,and verify your claim within 3 days-->that is if you really have what you claim ;)
Brad
