Entropy Engine
Started by abv, February 13, 2016, 01:07:21 AM
Nink
Quote from: pomodoro on March 10, 2016, 06:33:22 PM
The sad fact that a heat pump with a proven COP of 3 (compressor/vapor/liquid) system can't be made into an over unity device seems to indicate that this system probably also won't work. Imagine a system where 1kw heats a room with 3kw. This is not fantasy but real. But alas,those free 2kw cant be used to loop the system. How sad is that?
Fully agree Pomodoro and I really wasn't trying to suggest it was an OU design, just an interesting concept.  The challenge I have is every day. mathematically all of these types of proposals fall outside of Newtonian physics but one day we all hope we find a crack in the matrix.  It's a bit like Thomas Young's double slit experiment where suddenly the current model no longer holds so we now discover "quantum physics" (unless you subscribe to a mashup of a David Lapoint and Electric Universe theory).
sm0ky2
Quote from: pomodoro on March 10, 2016, 03:48:00 AM
Smokey, have you any links to this device? I couldn't find much after 10 mins of searching. Cheers Pomo.
the cooler + jet nozzle PM's circulated around colleges in the early 90's,
Coleman immediately changed the drain plug holes on all their coolers.
sm0ky2
reference?
pomodoro
Quote from: sm0ky2 on March 12, 2016, 11:04:55 AM
We need better info than this. Have you any plans? how did it work exactly.
Regarding the heat pump and references , it seems the temp difference is not enough. Something to do with the Carnot cycle, being the most efficient cycle possible and the DT being low. Its not just heat we need, its temperature differential. Guess you'd have to go through refrigerants and check the DeltaT and work out how efficient the Carnot cycle would be if used.
lumen
I think this video shows the reason why a Gadolinium engine would not work.
https://www.youtube.com/watch?v=mrthB0n-Yd4
